M30 cam replacement "rocker arm loader"
Anyone have one of the "rocker arm loaders" from Baum Tool or equivalent? I'm contemplating purchasing one of the Baums and wanted to get some feedback from someone who's changed a few cams on an M20 or M30. Seems like this would make it real EASY. Thanks, Mike
Yes indeed
George,
Yeah, that's the idea. Tabs welded to a "girdle". Is someone making them out there? Thanks, Mike
Re: Yes indeed
This is the factory part that I'm sure is long ago NLA.mbb wrote:George,
Having it done it both with and without the tool, I'll take the tool every time.
Its a little nerve racking because you really think the valves are going to collide but just before the valves touch each other you realize that there is enough clearance to slide the cam right out.
Follow the factory instructions and you should be just fine.
Bumping this.
Finally got my hands on one of these and went to use it.
Am I missing something? I got the tool on, but do I need other bolts to get it to go down? Headbolts are about 2.5" too short (mocked tool up on a loose head I had kicking around)
I can't seem to find the factory instructions for it either. Sure would make life so easy for me now.
- Beamter
When the head is on the engine in the car, as in if the banjo bolt was loose and the front half of the cam is worn out and you don't want to pull the head off the engine.tn535i wrote:I must be missing something? If rebuilding the head what is the need for this tool? I've just moved the rockers off the valve stems as needed to remove pressure and start pulling everything. It would seem to me the only reason for this tool is to replace the cam without touching the rockers?
Have to take everything forward of it apart, but it's much easier than taking the head off to remove the cam.
OK but I didn't think the cam could be drawn all the way out with the head on the block still in the car. And IF the cam is worn from lack of lubrication it would be a bad idea to use the same worn rockers on a new cam. Hard for me to think of a situation where the cam and all the rockers are not coming our together. Not trying to start an arguement, just don't get the value or practical need for that tool.
On an engine with bearing caps over the cam though, something like that makes sense to hold everything down then evenly relax the spring tensions after removing the caps to get the cam out. Like an S38.
- Beamter
No, you cannot remove the rocker shafts with ease. Even if clearances/head warp would allow it, the head bolts lock them in place.mooseheadm5 wrote:Using this tool allows you to pull the cam with the motor together, and yes you can get it out in the car (if you are clever.) From there, you release the tool and you can remove the rocker shafts with ease and replace any rockers you need to replace.
- Beamter
And even then, while some do have the factory manual described threaded plugs, many I've seen just have pressed in plugs, meaning you either need to drive them out from the end or push/pull them while grabbing them from the side. While I would love that tool, I see it as more saving time than allowing a previously undoable job to be performed.
