While replacing the battery in key head I noticed the little light bulb and was wondering if you know of a LED
Replacement?
Thanks
1988 m5 key light
Re: 1988 m5 key light
Any LED that will work with the voltage supplied by the battery and fit the key will work. Don't recall the battery voltage but if too high a dropping resistor is used to prevent the LED from dying. Shouldn't be hard to get one to work. Common sizes are 3mm and 5mm LEDs but there are others.
