M30 b34/b35 oil level sensor wire diagram help?
AJ
Post by AJ »
Does anyone know if it's possible to splice a m30b35 oil level sensor plug end into a m30b34 oil level sensor? or if there is any diagram showing what each wire is? Thanks
AJ
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
Wiring diagrams are available for download here: http://wedophones.com/BMWManualsLead.htm
Look at the "Active Check control" diagrams.
AJ
Post by AJ »
Mark 88/M5 Houston wrote:Wiring diagrams are available for download here: http://wedophones.com/BMWManualsLead.htm
:banana: Thanks helped out a lot
E28..... E34
Static oil level: Blue/Violet..... Blue/White
Dynamic oil level: Blue/White ..... Blue/Yellow
Don't have access to the car at this moment, did some reading and I remember the e34 had 3 wires and the e28 has 2 wires. Would the extra wire on the e34 be ground? but the reason why the e28 only has 2 wires is because it's grounded through the oil pan separately?
TheLazyDog
Post by TheLazyDog »
AJ wrote:... but the reason why the e28 only has 2 wires is because it's grounded through the oil pan ... ?
It seams so, although the diagram indicates it is not case grounded. 0670-10 (ground distribution) denotes that the oil level sensor is grounded by wire to G102 (at the fender), while 6216-2 (active check control) displays it is grounded by wire to G103 (engine ground).
BMW of North America, Inc. wrote:All wiring between components is shown exactly as it exists in the vehicle ...
I am shocked! Shocked! Well, not that shocked.
