Burned Out Battery (Alternator) Light Indictor...Major Drain
Preacher's 5
Post by Preacher's 5 »
Hey guys, I was wondering how many of you know that if the battery/alternator light bulb blows, that it will cause a negative drain on battery. Yesterday I started my car and let it idle to warm up, but did not realize that when I turned the ignition switch on the battery/alternator light was not on. When I turned the car off, it would not start. First I thought the battery was dead. So I waited about 10 minutes and the cars started right up. Then I thought I needed an alternator. Today, when checked the battery and alternator voltage, it was reading 11.2 volts. I know that it should 14. I called my mechanic, Wayne, and he told me to turn the ignition switch on and see if the battery/alternator light was on, I told him..NO! He told me to pull the cluster out and replace the bulb, then check to voltage, which I did...now it is reading 14.02 volts. WOW! Problem solved! Saved a couple hundred bucks! Car is cranking and running great.
I have owned this car for 35 years and had never heard that before. You learn something new every day. I wonder how many people have replaced their alternator, (as I was about to do); or replaced the battery because of a $2 bulb, (which I have a bunch of). Just curious and passing on some info. I truly thank God for my mechanic, Wayne Lins. Great car brain.
Shawn D.
Re: Burned Out Battery (Alternator) Light Indictor...Major Drain
Post by Shawn D. »
This is fairly well-known, but it's not intuitively obvious. This was also an issue on GM cars that used a similar circuit to excite the alternator.
FWIW, later instrument clusters have a resistor parallel to the bulb so that if the bulb blows, the alternator will still get power from that circuit.
Preacher's 5
Shawn D. wrote: Feb 17, 2021 9:27 PM This is fairly well-known, but it's not intuitively obvious. This was also an issue on GM cars that used a similar circuit to excite the alternator.
Thanks Shawn. 35 years and never had the issue until yesterday. Glad to know some-one else is up on that revelation.
BMWCCA2
Post by BMWCCA2 »
It was a fairly common issue on 2002s, too.
demetk
Post by demetk »
These cheap voltmeters are useful tools, if and when you remember to look at them :)
indycar89
Post by indycar89 »
demetk wrote: Feb 19, 2021 7:12 PM These cheap voltmeters are useful tools, if and when you remember to look at them :)
Nifty meter in the check panel - remember what/where you found it?
demetk
Post by demetk »
indycar89 wrote: Feb 22, 2021 6:39 PM Nifty meter in the check panel - remember what/where you found it?
https://www.amazon.com/gp/product/B00YA ... UTF8&psc=1
My check panel came apart easily so installing the meter wasn't difficult.
gadget73
Post by gadget73 »
Fords do this too. Not so much a drain, just it doesn't turn the alternator on. There is a resistor but its on the cluster so it doesn't work if you have that out for whatever reason.
I had a Beetle years ago that wouldn't charge, same thing with the bad bulb.
craigb93
Post by craigb93 »
indycar89 wrote: ↑22 Feb 2021 18:39
Where were you able to get the voltage signal from? Inside the Check Panel or ?
