Motronic parts FS
RossDinan6
Motronic parts FS
Post by RossDinan6 »
BMW Parts, from '84 633. All removed 6/05 during standalone installation. Finally pulled the box down from the shelf and offering up here hoping someone wants any of this before I dump them.
Offers.
Motronic ECU, 0 261 200 027, labeled 078
Idle control module 1 286 134 9 SOLD
Both position sensors, 0 261 210 002
Throttle position switch, 0 280 120 302
AFM, reman dated 3/4/05. No P/N on the part, per realoem: 13621277564
Dinan Turbotronics piggy back unit
6 injectors, probably could use cleaning, the car ran fine on them. SOLD
Either the ECU or the piggyback were the impetus to go standalone, One was causing fueling issues, I suspect the Dinan. Everything else was functioning, but redundant after the swap.
RossDinan6
Re: Motronic parts FS
Well, I just noticed I put this in the wrong place. Mods, care to move this to the right sub forum?
Done.
Jondoe
Post by Jondoe »
Hi do you still have the position sensors and if so what do you want for both?
Reply at
rrm1963@gmail.com
