Holy Grail Labs - M30B35 Intake Manifold Bracket
Re: M30B35 Swap? You need one of these brackets.
SOLD OUT.
There are no more.
There are no more.
Re: M30B35 Swap? You need one of these brackets. [SOLD OUT!]
Bump.
Should I make more of these?
I'm Interested
I'll take one.
I'll take one as well
Hi Charlie,
I would be interested in two if you are willing to ship (at my expense) to Nova Scotia.
Best regards,
Mick
Best regards,
Mick
I'm in for one - possibility two.
In for one also.
Cek am also interested should you decide to make more.
I guess I need one.
I'll take one.
I usually arrive late to these things, but 8 years? COME ON, MAN.
I'm in for one, powdercoated black if possible but I'll take whatever form it comes in. Pleez pleez pleez Thanks!
hey @cek - if you aren't planning to fab more of these, would you be open to the idea of sharing the fabrication file you used to make them?
just a thought, for those of us stragglers just getting started on M30B35 ownerhsip...
I'm working on getting more made now (via Holy Grail Labs).
Re: Holy Grail Labs - M30B35 Intake Manifold Bracket
would you want one of these brackets for a stock 1988 535is?
No.
The M30B34 intake manifold is supported by two struts that bolt to the valve cover and a small bracket between the block and the bottom of the manifold.
The M30B35 does not have those ugly struts above and is instead supported by a beefy aluminum bracket connected to the engine mount.
The shape of the E28 engine mount prevents the aluminum M30B35 bracket from fitting. The HGL E28 M30B35 Intake Manifold Bracket is a simple, robust, solution to this problem.
If you don't have an M30B35 swap, you don't need one of these.
Would like to order one !
The new supplier provides powder coating (the old one didn't, so I had it done separately). To ensure they get the bends right we need to order a prototype.
I should have it next week...
On the last run, I lost money because I didn't factor in prototypes and coatings; this time around we need to make a bit of profit so they'll be pricier. Not sure exactly how much yet, but hopefully under fifty bucks each.
Count me in for the next run.
I will take one. Sign me up. Holy Grail Labs is the bees knees.
Travel (to Argentina because I predicted they'd win the World Cup) meant I couldn't get the prototype until today.
It's here and appears glorious.
I will test-fit in Vlad asap and if it fits as well as it looks a production run will start.
We'll be putting up a pre-order page on www.holygraillabs.com RSN.
Pre-order page is up at
https://www.holygraillabs.com/products/ ... ld-bracket
It will likely be a month before we have production units ready to ship. If you are willing to buy now and be patient, we're offering 15% off. Use discount code "MOARBRACKETS" at checkout.
Preordered! MOAR EXPECTATION NOW!
