SQL Injection attack detection
cek
Post by cek »
Overly aggressive SQL Injection attack detection?
http://www.mye28.com/search.php?keyword ... wn+wire%22
Re: SQL Injection attack detection
That's interesting. Did you use the "start trouble ticket" link or did you only post this here?
Hopefully Justin sees this soon and can offer something more helpful.
cek
Post by cek »
Jeremy wrote:That's interesting. Did you use the "start trouble ticket" link or did you only post this here?
I did see that; for some reason I felt it wouldn't work. That was dumb of me. I guess I just assumed there's no way there's actually a support ticket system behind mye28.com. Like I said, ASSUME.
I've now clicked on that nice blue link and see that all it does is send an email. Which is awesome. Email sent.
This thread was spectacularly unhelpful.
cek
Post by cek »
wkohler wrote:This thread was spectacularly unhelpful.
Here, maybe this photo will help:
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Perfectly valid block, really, from a security standpoint. But I did raise the triggering threshold to a maximum of 4 double quotes for the time being. It was 2 before and phpBB probably escapes the strings correctly to prevent injection attacks so we may not need the extra cautiousness. The security logs are full of injection attacks from compromised machines, though, they are not sending command code enclosed between %22s.
