Picture request - amplifier / subwoofer installations
landspeed
Post by landspeed »
D Unit wrote:Hey Landspeed,
Did you have to drill out your door frame too even if your speakers only had a 1.65" depth? Is the grill simply mounted to your door card? Did you use a speaker baffle for the speaker to door frame?
I did not have to cut the actual door metal, there is a kind of concave area that sits close to the window frame. I did screw the speaker into the door metal to sandwich the speaker between the door card and frame. Not much space between the door card and door, but just enough.
D Unit
Post by D Unit »
I got my 15" Q logic speaker baffles from Ebay the other day. I am going to use them to try to mount my 15" Image Dynamics IDQ infinite baffle. I already used the circular hole from the baffle as a template to cut out the hole behind the rear seats. Using a rotozip, it literally took less than 4 minutes.
Mless5
Post by Mless5 »
I used to have a 15" in IB - greatness! IDQ sounds great in IB, but excursion is on the shy side.
thrty8street
Post by thrty8street »
Great thread, will be back with pics to post my setup.
D Unit
Post by D Unit »
I took the day off today to try to get my system finished up but I didn't like the way my amp rack turned out. The only thing that turned out nice was the 15" IDQ mounted IB.
D Unit
Post by D Unit »
For those that added speakers to their doors (Spen and Landspped), how did you run the wires from the door panel to inside the car???
D Unit wrote:For those that added speakers to their doors (Spen and Landspped), how did you run the wires from the door panel to inside the car???
Fish them through the rubber boot that contains the power window wiring. You'll probably have to pop the boot loose from the door and/or door frame to get them through.
Marco77
Re: Picture request - amplifier / subwoofer installations
Post by Marco77 »
Just curious if anyone knows the inside trunk wall width? My car is in storage and thinking of building an amp rack over the winter. Cheers
