Thanks to Matt at JustJap Australia, shorter coilover inserts were sent at no cost. New ones are approximately 60mm shorter, giving the height i wanted.
And it now tucks a decent amount of tyre without having to adjust preload from factory specs.
epearce wrote:Thanks to Matt at JustJap Australia, shorter coilover inserts were sent at no cost. New ones are approximately 60mm shorter, giving the height i wanted.
Is that at the lowest setting?
Rear has since dropped about 20mm. That photo doesn't have front coilovers fitted. Fronts will go lower than you can safely drive at. Currently have a 3mm gap between the top of the tyre and bottom of the guard when on full lock. And i can go about 40mm lower than this, but obviously i couldnt turn the wheel very far.
All this is without adjusting preload away from factory spec.
I know this was a thread about BC but i'm ordering Fortune-Auto from the local distributor here in Montreal.They be installed on my 1988 E28 535i
I've got to decide on spring rates. They're suggesting 10k/8k for a daily or 11k/9k for a bit firmer ride.
Any suggestions from you guys would help.
Are the BC dampers the same diameter as the stock ones? In other words, could I buy the shorter BC dampers and modify them to fit into my strut housings?
D Unit wrote:Are the BC dampers the same diameter as the stock ones? In other words, could I buy the shorter BC dampers and modify them to fit into my strut housings?
No. You need their sleeves for the dampers. The dampers thread into the sleeves. That's how you adjust ride height.
Understood. But I was thinking about using their shorter dampers for those of us using a custom coilover kit and already have threaded sleeves over the strut body. I called BC yesterday and they said most of their dampers are 51mm, but do have 45mm dampers used on e30s which "could" fit.
Jay texted me yesterday and said e23 and e28 are both 44mm wide. The BC e30 dampers at $95 each could be a nice option versus buying shorter Bilstein/Koni inserts (325ix, g60) and then having them revalved.
I know. It's heresy and stanceworks --> is that way.
I should have explained it in a bit more detail. The strut is threaded. The strut sleeve is threaded on the inside, not the outside. So you adjust ride height by turning the complete strut in the tube.
I just got mine as well. Custom valved with swift springs, 7k F, 8k R. Will have to see how rides once together. Will be on the ground hopefully within 3 weeks after 10 months on jackstands.
I'm gonna bump this thread from the dead, because I am looking into BC Racing camber plates.
BC Racing claims their camber plates ONLY work with their coilovers, and I am thinking that is BS.
OP, do you still have your BC coilovers? What is the diameter of the threaded shock shaft that goes through the camber plate? What does the bottom of the camber plate look like?
iamcreepingdeath wrote: ↑Apr 07, 2021 12:25 PM
Thanks
They are probably compatible with E30 BC camber plates. If they fit the shock you are snugly around the shaft of the shock and sit on a shoulder, tighten without binding and fit the stock top hat bolt pattern. Theyll work. Don't see why you think it is bullshit that camber plates for a generic 3 piece coilover wouldn't be compatible with other shocks....
LeiseyJr wrote: ↑Apr 08, 2021 12:45 AM
I think it is BS precisely for the reasoning you gave in your first three sentences. I agree with you. I don't see why BS camber plates wouldn't work with other shocks, at least with any spacers that may be needed...
What I am looking for is some proof, before I dump $200...
Forgot to mention it needs to somehow have a perch for the top spring. But ig you can fab that up or adapter something.
I’d at Ireland Engineering’s camber plates for e30, whether spec e30 or race ones, Vorshlag or Ground Control (these dudes have E28s ones)
E30 top hats are the same, might be better to go down one those routes IMO.
nik77356 wrote: ↑Apr 09, 2021 9:55 AM
BC Racing's Shock Shafts are a different diameter than most other Coilovers. That is why they won't work with most other Coilovers.
I just spoke w BC racing. The diameter of the threaded portion of their shock shafts for the E28 is 12mm, which is the same as the Koni shocks I have now, which is the same as the stock shocks. The length of the 12mm OD section is 110mm.
Given that information, I don't see how their camber plates cannot work with my E28 coilovers, so I am somewhat confused with BC Racing's insistence that their camber plates ONLY work with BC Racing shocks.
LeiseyJr wrote: ↑Apr 08, 2021 10:59 AM
I currently have a home-made coilover system on my E28 with standard 2.5" Eibach springs and Koni yellow shocks, with standard 2.5" spring hats.
