e34 M30B35 turbo build
Tiit
Re: e34 M30B35 turbo build
Post by Tiit »
Interesting project. Looking forward to next update.
spaze34
Post by spaze34 »
So I received my King Bearings finally... I inspected them and started getting bench/shopcleaned up to prepare for plastigage and main/rod bearing installation.
4 of my 12 mains from KING bearings had imperfections and knicks -_- ... so I will NOT be installing these.... I will be ordering some Glycol bearings from Ireland engineering
Imperfections in the KING bearings (new,,, fresh out of box -_-)
ImageIMG_6784
ImageIMG_6783
All of the rod bearings looked good after inspection so I went ahead and plastigaged' all of them and got them in...
ImageIMG_6785
Plasti-gaged' every rod'
ImageIMG_6788
ImageIMG_6790
So... while waiting on my new set of main bearings I went ahead and painted the block and got her all prepped for assembly
ImageIMG_6781
Pavel
Post by Pavel »
:beer: :popcorn: Looking fwd to progress
tcturbo91
Post by tcturbo91 »
I put an S366 on my car recently and it is definitely laggy. came from a comp T04e 61mm which spooled quickly. I too was looking for more and I probably went too big. I will say once the car builds boost its like a freight train but just depends what you are looking for. keep up the good work!
Shadow
Post by Shadow »
still alive?
spaze34
Post by spaze34 »
Good morning!
I have been busy with life and I had a little side track swapping an S52 into the wife's DD :)
https://www.bimmerforums.com/forum/show ... t-S52-swap
Anywho... I finally started getting specific parts in that I need...
Picked up BW S300SX3 66 in the T4 flavor...
ImageIMG_4151
RSI Manifold should be delivered next week and I will start assembling the top of the engine... I need to figure out what clutch to run though
spaze34
Post by spaze34 »
Progress...
-Megasquirt PNP ordered with GM iat and wasted spark set-up.
- GC coilovers w/ 550/450#
** Still need to decide on a clutch... open to wisdom!
ImageIMG_4195
ImageIMG_7119
spaze34
Post by spaze34 »
Weekend progress... (Aug, 18-19,2019)
I received some goodies in the mail. Thanks to Todd at TCD for help sizing stuff and helping me confirm sizing of items for my build...
ImageIMG_0508
ImageIMG_0472
I am buttoning up the oil/timing chain assembly, although I forgot to order the oil pump chian tensioner...waiting on it to arrive now.
Oil Pump Chain Tensioner
BMW Part# 11-41-1-705-055-M9
Any of ya’ll rebuild oil pump?... or just clean, inspect, and reinstall?
ImageIMG_0489
I also pulled the car out, decon’d and used fall-out remover to get shop dust/metal dust off paint… cleaned engine bay to prep for painting.
ImageIMG_0496
ImageIMG_0494
ImageIMG_0502
ImageIMG_0503
Shadow
Post by Shadow »
hell yeah get it done. :)
i'm not a fan of that kevlar clutch you will burn it alive before you can make good use of that turbo.
marc79euro645
Post by marc79euro645 »
I've had good luck with my clutch masters clutch (10 years+). I don't abuse it like I used to, and only drive it once in a while, but, it still works great. I'm only making about 350ft#, so I guess it depends. What are you using Shadow?
spaze34
Post by spaze34 »
Shadow wrote:hell yeah get it done. :)
Did you run the segmented kevlar... this clutch?
Did you do the 800-1000 mile break-in period? I talked with Todd at TCD and this was what was recommended... although I do not want to get it together and have the clutch slipping once I get the tune nice...
Thank for any input !:)
marc79euro645 wrote:I've had good luck with my clutch masters clutch (10 years+). I don't abuse it like I used to, and only drive it once in a while, but, it still works great. I'm only making about 350ft#, so I guess it depends. What are you using Shadow?
What clutchmasters clutch are you using?
Shadow
Post by Shadow »
yup! That same clutch.
kevlar never ever ever breaks in it's like cloth. That's why kevlar lasts forever if not abused.
i wouldn't go past 450tq to keep it safe but once you overheat it it'll never be the same.
it's a good clutch but just saying if you have a 66mm turbo you won't get near what that turbo can do
with that clutch. 57mm would've been better.
here's my flywheel after years of work.
still as new. pretty impossible to break in kevlar at 500mi or 1000mi.
not talking shit it's a great clutch but it'll over heat even if you do get to 500tq, once, then melts.
i did it on the dyno it smelled the room but it held.
Imagekevlar never beds by jet jones, on Flickr
i'm using the ceramic one no lie it feels about the same as the kevlar
was ready for it to be a grippy chatter monster, but it's fine! Also got from TCD :)
btw a good hack to save the clutch is to get your tq and raise boost with rpm to keep torque as flat as you can
so you ride that safe tq to redline making as much HP as u can.
i think mine made 460tq at 16psi then raised it to 18psi after peak and made 480hp. raise it to 20psi. whatever just keep that tq flat.
mine just ran out of injector so 19psi was the limit 4 me for now.
ImageBalance puck by jet jones, on Flickr
spaze34
Post by spaze34 »
Shadow wrote:yup! That same clutch.
Shadow, thank you for this! This will hopefully help me dodge a big bullet!
I am going to reach out to Todd at TCD and see if I can go an exchange or some sort. Thank you for the help man, much appreciated.
Do you have specs on your build?
-Turbo type/size
-Injector (style/size)
-Engine management
-Fuel pump
The more knowledge I can gain from other set-ups the better!
marc79euro645
I'm not sure, but ,I don't remember mine being segmented (10 years and c.r.s.). It was a kevlar from clutchmasters , I'm sure of that. Sounds like you and Shadow are at another level though.
Shadow
Post by Shadow »
theres even a recent change in their PP
its a different PP with different fingers and is balanced compared to the one i got like
5 years ago or who knows how long which was not balanced btw.
spaze34
Post by spaze34 »
I was able to get some work completed...
-Turbo Oil Drain Line (1/2" NPT - 8AN adapter)
-Lower timing cover/ Oil pump / timing chain/tensioner/ guides/ water-pump
-A/C / PS pump brackets
-Oil filter housing
ImageIMG_0592
ImageIMG_0594
ImageIMG_0595
ImageIMG_0598
ImageIMG_0602
q20v
Post by q20v »
I've been following you build for a while now and it's coming along nice. Slowly... but nice. :laugh:
I like your turbo oil drain location on the block. What's the black metal sleeve that's in there?
Dubs
Post by Dubs »
F
e30 Alpina B6 3.5
Post by e30 Alpina B6 3.5 »
Great project!!
Shadow
Post by Shadow »
ya great project
did it die?
e38740imd
Post by e38740imd »
bump for updates
good or bad
