M5 Clutch mechanism
grahamg
M5 Clutch mechanism
Post by grahamg »
Are the E28 M5 clutch Over centre spring, master and slave cylinder the same as in the M535i?
Re: M5 Clutch mechanism
Let me introduce you to RealOEM: https://www.realoem.com/bmw/enUS/select Find the P/Ns for those, then put each into the "PART NR APPLICATION SEARCH" box, which will give you a cross-reference on which models used the same part.
I can tell you that the over-center spring is the same for the M5/M535i/535i. You'll have to look up the others.
grahamg
Post by grahamg »
Thanks Shawn, will check it out now
