Hello All,
Lately, and now and again, I have been getting a "Brake" light flicker on the dashboard. It usually occurs after some thrashing of the M5 on the back roads of NW Connecticut. Then it disappears for a few days. Brakes are in good shape, rotors, pads, etc. Is this a warning of a failing brake pressure regulator, master cylinder, hydro accumulator? Brakes feel tight and true. Any thoughts would be greatly appreciated.
thanks,
jeff
Quick brake question
Re: Quick brake question
With the engine running at idle with the car stopped push the brake pedal 2-3 times quickly, hard. If the light flashes you might have an accumulator that is going bad.
Your thrashing may be setting the brake fluid level indicator off. Maybe add some brake fluid to the reservoir so it doesn't trip the light.
Thanks for these replies. I will start with these.
best,
jm
best,
jm
I had that show up when I took turns hard years ago. I remember it being the cap was missing that rubber/foam seal on the reservoir.
I had this happen years back and it turned out being a brake pad sensor wire shorting out. My wires as they exited the fender well wall were all cracked so I just bypassed the wires and now run without pad sensors. Might not be your style though.
Thanks guys. Philo, that brake light you are referring to is the "brake lining" light correct? Mine was just "brake". I think it signals different things? Thoughts?
best,
JM
best,
JM
Sorry, but it's been so long ago I can't recall. But I found this diagram showing the warning indicators. Hope this helps.
Brake lining is a different light.
Brake is either a problem with pressure or reservoir level.
