WTB Fresh air "under-hood scoops"
I have no idea what they're called nor do I have the part numbers. Realoem doesn't show them as part of the hood diagram.
Whatever they're called I need em and possibly what they close with on the firewall side cause what i'm breathing in the cabin certainly isn't fresh air.
Edit: I think I may have found the part numbers.
Looks like #6 & #7
Sound insulating left 51 48 1 904 313
Sound insulating right 51 48 1 904 314
[/img]
Looks like #6 & #7
[/img]
Are they plastic?
If mine are useable I'll ship the pair for $20.
$27 each for new is a great price.
I would not buy or sell these parts used after attempting to remove mine.
They show up at $34 each (part numbers 51481904313 & 51481904314) @ getBMWparts.com You will most probably need the seal pieces (part numbers 51231870527 & 51231870528) for $3.61 each. be careful when removing these as there tends to be hidden rust (that edge on my hood was almost gone on one of the sides!).
Good stuff. Thanks.jimoreno wrote:They show up at $34 each (part numbers 51481904313 & 51481904314) @ getBMWparts.com You will most probably need the seal pieces (part numbers 51231870527 & 51231870528) for $3.61 each. be careful when removing these as there tends to be hidden rust (that edge on my hood was almost gone on one of the sides!).
Re: WTB Fresh air "under-hood scoops"
Anybody know where we can source these? Have had a hunt around in Australia without much luck.
They are available from BMW. I just bought a pair for my 535is
What did they sting you?
I'd of thought W&N or ECS might have carried them?
