kojo96 wrote: ↑Jan 20, 2023 8:04 PM
It's almost impossible to see the pedal bracket crack while it's in the car. It has to come out and viewed in good light.
Try having someone sit in the car and depress the clutch pedal in/out, you look under the hood for any movement in the brake master cylinder, it should not move at all. The tinest movement indicates a cracked pedal bracket.
On one of my cars, the master had significant visual movement when the clutch pedal was depressed. Pulled the pedal bracket and sure enough, was cracked badly.
After completing this test, it does not seem like there are any cracks in the pedal bracket. No movement was found in the clutch play.
