Parting a 528e in St Louis
1983 painted a custom green
Perl Beige door panels and rear seat
F/R Glass - $25 each
Front Doors - $40
Rear Doors $20 - No rear motors
Hood and trunk lid - $50 each
5 speed swap - $800
Priced for local pickup (St Louis)
Front Doors - $40
5 speed swap - $800
Re: Parting a 528e in St Louis
Hi there, I need a black, rear seat ashtray (and fastening bolt) if you have it. PM me and let me know.
Thanks
Thanks
I'm looking for door caps! Black ones!
The piece that sits on top of the door card on the inside!
And also the door handle surround pieces if you have them and they're black!
I am looking for the Trunk kit surround in the trunk.
I am looking for a outside temp sensor, P/N#65811385337. PM me if you have a working one.
This 1983 528e has a clock instead of OBC, so no temp sensor.
I just realized that my L6 parts car should have one//
I’m interested in rear seats if you’re willing to ship
I sent you a PM, no reply?
Is it a manual? I wanna do a swap
Hi I am looking for the two rear window motors without the regulators.
Thanks
Thanks
The swap kit is now available for $900
M20 with broken timing belt $50
Sunroof motor $40
Sunroof motor $40
Windshield?
Hi. I would like to buy the two rear window motors without the regulators.
Thanks
Thanks
I tried to PM you twice but it stays in the out box. I also sent you an email. But Bottom Line I’m interested and want to discuss it further with you
Koopman, I plan to pull 4 or 5 motors for you.
Shammy, I tried to reach you as well. Will try again.
Mye28 world: Is it worth saving any sheetmetal? Unfortunately the front fender bottoms are rusted, but the nose and rear quarters are okay.
Hi. You can reach me at: harry.malkasian43@gmail.com. I will buy what e er amount you have for E28 Rear Window Motors ASAP.
Thanks
Thanks
Bill: I could use the right rear door edge protection moulding (the "mouse fur" trim) if in good shape. Let me know.
Thanks,
Mike
Thanks,
Mike
Do you have the rear piece (covering the lights) trunk liner?
Do you have the metal trim pieces above the doors that are part of the gutter?
I now have the engine out and ready to go.
turns easily
timing belt likely broken
Not a super eta.
I will take a low ball offer, or scrap it, or somebody tell me what parts of of it are worth saving.
turns easily
Not a super eta.
I am interested in the full in-tank fuel pump assembly, and the Idle Control Module (ICM) Its the green box in the glove compartment above the ECU, just need to unscrew the 1 screw mounting the cad plated bracket and unplug it. Both should easily fit in a medium flat rate box to 06606.
I can remove and ship the cylinder head. Make me an offer.
Hi. Looking for the two rear window motors without the regulators.
Thanks
Thanks
Hello,
I'm interested in the ECU if it's available. I don't care if it works (kinda prefer that it doesn't). I assume it's the 35 pin cast alu box kind.
Thanks,
Z
Thanks,
Z
