I converted my 1983 M30B32 to M 1.3, so I have the leftover 1.0 specific parts and a few other E28 & E32 items hanging around:
-008 DME
-AFM
-Idle Control Valve
-Flywheel Sensors
-Single Tooth Harmonic Damper
-Set of 6 Fresh "Design 3" Injectors with 4-port Nozzles, New O-rings ***Remember: M30B32 uses 24 # low impedance injectors
-Almost New Standard Motor Products Brand FPR
-Remains of Unwrapped OEM Engine Harness. Fuse Box Connector and a Few Other Connectors are Removed
-2 Pcs Idle Control Unit- 1 Green, 1 Blue. Both Seemed to Work OK.
-Coil Wire
Also-
-BMW Brand E28 Door Cup Holders in Black
-Set of E28 Black Front/Rear Hexomats in Good Cond.
-Full Set of Rear Speakers from a '93 E32, Other E32 HVAC Parts like "Sword"s, Blower, Aux Coolant Pump, ABS Hyd. Module, Other E32 Parts.
-3 Pcs OEM 14" E28 Bottlecap Wheels in OK Condition w. Decent Tires, 1 Pc TRX Wheel w. Very Bad Tire (Pickup only)
PM me with any needs. I'm definitely not looking to get rich off any of this. Just can't bring myself to chuck it. Thanks!
FS: Motronic 1.0 Specific Parts and More
Re: FS: Motronic 1.0 Specific Parts and More
DM coming..
