1980's Callaway kit for the M30.
This is a complete setup of all the hard parts you would need+ some leftover parts from the Callaway set that was on my long gone 535.
This is by no means bolt-on ready. Turbo has significant play and would be best rebuilt or replaced with a more modern unit. Wastegate should be rebuilt as well.
Hoses/lines/rubber couplings are all old and should be replaced.
Callaway Intercooled M30 Turbo Kit $2,000
Re: Callaway Intercooled M30 Turbo Kit $2,000
Where is the microfueler controller to go with the hardware?
I still have mine but it appears to be missing in your 'kit'
Why would you bother with the krappy microfueler?
Sawing off the 7th injector bung and using bigger injectors/rising rate, or M/S seems like a better idea.
Pretty much any of the modern alternatives to the microfueler are safer and easier.
Just tripped over this bump
