Bought these for my E30 several years ago but replaced them with H1/H4 setup. Barely used, in original boxes, with Lamin-X 'French' yellow protectors. (Can be removed, if desired.)
Lights were never used without the Lamin-x so the glass is perfect. The film is not perfectly flat all the way around the outer edge of the lens but I think with some heat from a hair dryer it would lay down properly. (But I haven't tried it.)
As far as I can tell, Hella doesn't offer these anymore.
If you're going to run sealed beam US DOT headlights, might as well be Hella's right?
$40 for the pair, plus actual shipping.
FS - Hella H5001 high beams
Re: FS - Hella H5001 high beams
PM'ed. Thank you
Sold. Thanks
