FS: Triple USB charging port switchblanks
cscracker
Post by cscracker »
For anyone looking for USB charging ports that fit into the BMW switchblanks, I designed this part:
https://www.shapeways.com/product/ZBPV4 ... 4&li=shops
Combine this with USB charging modules, hold together with M2 screws, connect a 12 volt power source, and there you have it. I'm not assembling these, it's a DIY solution, but it's a really simple DIY.
Some examples of the charging modules you can use with it:
https://www.aliexpress.com/item/3281517 ... 4c4dR5jqLK
https://www.ebay.com/itm/24W-USB-QC-3-0 ... SwJBdfuEOz
I also created a plain switchblank, to replace BMW part 1 368 498:
https://www.shapeways.com/product/MH7SE ... -inventory
Sometimes you can find the original ones, sometimes you can't, so I made it as an alternative. The texture match isn't perfect but it's pretty good and blends in. Red, white, and blue are available too.
If you'd like a custom switchblank for some other device, I'm happy to take requests. I'm working on one for QC4.0 modules that have USB-A and USB-C ports now.
jsedita74
Re: FS: Triple USB charging port switchblanks
Post by jsedita74 »
im confused . so its 25$ for the blank alone?
cscracker
Post by cscracker »
Yes, the product for sale is just the plastic part. Unfortunately Shapeways' printing costs have gone up quite a bit lately so it is more than I'd like it to be, but I imagine it's due to the current global situation. I reduced it a dollar as the price went up again since I priced it.
Picture of just the plastic parts:
To assemble a complete unit, you'd need:
- One of my printed models - $24
- 3 USB modules ($3.72 for 3 of the one I linked at aliexpress)
- 2 M2x8 screws ($3.29 for 10 on amazon)
- Some wire, soldering iron, and solder
- Connectors as necessary for your installation preference
So, you're looking at about $35 for all the parts needed.
It seems every time I edit something on a product, including the price, they go under private review, so it's unavailable right this minute but should be back up shortly.
DavidE9
Post by DavidE9 »
I just received and assembled mine.
Rather go through the 30 day shipping time from Alibaba for the PCB, I bought these:
https://www.amazon.com/gp/product/B07SD ... UTF8&psc=1
After filing down the excess solder on the back of the PCB, they fit right in.
Nice job on these. Thank you.
-D
thrty8street
Post by thrty8street »
This is a great idea. Do you have more pictures or a diagram showing how you wired the USB modules?
cscracker
Post by cscracker »
I'm glad you like it, thanks!
The modules just take +12v and ground, really simple to wire. I hooked them all to the same connector, but you can do it however you like.
QC 3.0 has a peak charge rate of 36W, so at 12 volts, that's 3 amps per module, plus whatever the circuitry itself needs. So, you're going to want a 10 amp or greater capable source if you intend to use QC 3.0 on all 3 modules at the same time.
I have two different types of modules, and I measured the idle current draw - one type (black ones from ebay) draw just under 5mA (as a set of 3 modules), the other type (red ones from aliexpress, pictured) draw 2.5mA (as a set of 3 modules). So, if you drive the car regularly, you could hook these up to always on power and they should be fine, but if not, you may want to put them on ignition-switched power so they don't drain your battery.
For always-on, cigarette lighter is a pretty good choice if you want to tap in, or you can just run a dedicated circuit from the battery or accessory fuse box, just make sure it's fused either way.
For switched, you're probably going to want to tap into a circuit on one of the unloader relays. The door chime is only on an 8 amp fuse so I wouldn't recommend tapping into it directly for this, but you could use it to trigger your own relay. Same with the OBC and clock.
