Motronic 1.3 conversion for M30B34
The Motronic 1.3 conversion kit™ comes with everything you see here!
(click to expand in new tab)
Comes with new bosch o2 sensor, temp sensor, temp sender, oil pressure switch. ECU, harmonic balancer, oil level sender, crank sensor with bracket and hardware, throttle position switch, harness mounting tabs and hardware, ignition wire set with inductive pickup and cover, and power wire isolator block.
Paypal F&F, checks, and USPS money orders accepted. 575 shipped for M30B35 harness rewrapped with super 88 3M tape, soldered quick release connectors and adapter plug for e28 fuse box.
Re: Motronic 1.3 conversion for M30B34
Well I could have used this whe. I was doing g my swap last month when you stopped responding
Was waiting for the harness to be shipped
TBH ive had half a dozen people send me emails etc and after like 20 emails no money is ever sent
That stinks. Sounds like craigslist.Bimmerguy2002 wrote:Was waiting for the harness to be shipped
Well I waiti g for a response after txting you and emailing you I had got nothing in responce
But I went with a eta harness
Have 3 kits with b35 harness atm, $35 off until 11/28/15
Newb question here... what is the benefits of converting to this?
Bigdoug92 wrote:Newb question here... what is the benefits of converting to this?
300+ HP
Ok kidding, but slight improved fuel economy, possibility to use megasquirt with the way the harness is designed, more aesthetically pleasing, chip availability, removes cold start valve, flywheel reference sensors, replaces broken connectors, gives an engine check light if you connect an additional wire.
Just sent you a PM.
Good afternoon, given the date, do I still qualify for this above?Bimmerguy2002 wrote:Have 3 kits with b35 harness atm, $35 off until 11/28/15
My actual car is a US Spec manual 86 b34 running on Motronic 1. Since I tend to be somehow Moronic when it comes to electronics but thinking ahead anyway, I'd like to ask you:
-Is it possible to run a "Euro dirty engine" minus the 061 ECU and use your kit with the 1.3 you're selling?
-If I decide against building a Euro dirty engine but instead turbocharge my actual b34 will your kit still work?
-Lastly, what year and model does your kit comes from, in the event I need to replace something?
Thank you!
Jack
harrypalmer wrote:Good afternoon, given the date, do I still qualify for this above?Bimmerguy2002 wrote:Have 3 kits with b35 harness atm, $35 off until 11/28/15
Thank you!
Jack
Yes.
The kit will work fine for the higher compression M30 you have, runs like a b35 with the same compression ratio.
If you turbo you WILL need to address the issue of standalone like MS, but the 1.3 makes it easier to use.
I use all non EML E32/E34 harnesses, you can call it a 1990 E34 535i M30 for your question.
Thank you for all your answers!
I don't have a Euro dirty engine yet but may convert my Us Spec B34 into one.
Please pm/email me or otherwise your Paypal account # for payment. Thank you once more.
Jack
Jack
What wire do I need to connect for the check engine light@
c3p0 wrote:What wire do I need to connect for the check engine light@
black is for tach, grey is for CEL, and violet black is for the fuel econometer under the tach
Is that right by the computer? I have the seta harness
if its going in an e28 then you dont have to do anything, you just plug the c103 together, its the white rectangle plug next to the ECU.
It's in my 84 533. Do you have a pic of the plug. Pm me
I don't have the check engine light on my dash
continue this in the b35 faq post so it dont become bloated. Check to see if the bulb exists in the back of the cluster first.
Still have a complete 1.3 kit? I need one!!
You have a pm
have two more kits, one is manual so for manual trans only, the other auto which works for both (people wanting to use MS)
Pm'd about manual kit
