Custom S38 For Sale
Philo
Custom S38 For Sale
Post by Philo »
This is a built S38 stroker engine that started with an Stock 88M6 3.5 liter S38 that had 26k miles on the clock. The M6 was based in Palmdale California and suffered a car fire in 1992. The engine was purchased from a salvage yard in 2004. Over a period of several years the engine was massaged and loved to its present state. From approximately 2008 to 2013 the engine was rebuilt slowly taking all the time needed to ensure quality work and not to miss any steps. The plan was to use the engine in a daily driver E28 M5, but in 2014 decided to do the S54 swap into the M5 and hence decided to sell the S38 stroker.
The S38s engine configuration is 86mm stroke X 95mm bore resulting in just under 3.7 liters. The compression is 11.0 to 1 achieved by Metric Mechanic custom flat top forged pistons. Pistons are sealed by Sealed Power standard moly coated rings. Bench tested compression is 220-230 psi, with #6 cylinder showing 200 psi. Paul Burke, who assisted in the engine setup states "no problem , and will work itself out at break-in." The bores were cut and honed with attached torque plate leaving a perfect beak-in cross hatch. Each piston was numbered and the bores honed to match each corresponding piston. The entire lower end has been balanced professionally, the connecting rods were weighed and adjusted so that the weight of the small-end matched and big ends matched, resulting in the total weight of each con-rod matching each other. The crankshaft from a Euro E34 M5 was machine balanced, counter weight adjusted, and journals micro polished.
The cam assembly was completely replaced with new cam gears, chain, guides, and S52 tensioner. The intake cam is a custom Metric Mechanic high lift rally cam, the exhaust cam is a stock E34 M5 cam. The bolt holes on both cam gears were hand slotted, location pins removed, to allow for custom cam timing adjustment. Cam overlap/timing was set custom by Paul Burke.
This engine is designed to run a dedicated programmable engine management system in full sequential. The 60-2 toothed crank hub is from a 1992 e34 5 series. The exhaust cam timing magnetic rotor and hall sensor is from the E34 M5 as well. A Vipec V88 engine management system is available for a separate cost. There is also a custom made wiring harness that was built to spec to run the V88 on a E28M5/S54 conversion and can be converted relatively easily to run the custom S38. Also sold at separate cost.
The intake system is the E34 M5 airbox/plenum and throttle bodies. The airbox was cleaned, walnut shell blasted, washed multiple times, powder coated with black crinkle, and reassembled. The E34M5 throttles where also dismantled, ceramic coated light silver, some of the metal parts nickel plated, plastic shims replaced new, vacuum tube o-rings replaced, throttle bar bearings replaced new, and assembly hardware replaced new.
http://phil.infostreet.com/M5_Images/B3 ... 010010.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010008.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010005.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010001.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010003.JPG
The engine was completely disassembled, the block was magnaflux tested and bored to spec (95mm) to match the Wiseco custom pistons. The pistons were purchased from Jim Rowe at Metric Mechanic and came modified to include additional oiling holes and relief slots in the skirts. Standard for Metric Mechanic pistons. Prior to installation of the pistons they were blue printed, weight matched and checked for proper wrist pin/deck height to ensure even compression. After installation into the block the piston deck height was verified once again.
The entire rotating assembly was blue printed and balanced prior to assembly into the block. The crank, a 1993 E34 M5 86mm, was balanced with the Metric Mechanic lightened flywheel attached. The stock S38 connecting rods were weight matched as well. Main and rod bearings are Glyco. Bearing tolerances are stock for the S38. The oil pump was also purchased from Metric Mechanic and is their reworked high pressure pump.
The S38 head was sent out and rebuilt by Rick Kemph of San Pedro, CA, who is well known for head work on S14s, S38s and everything else that is performance based, even aircraft engines. Rick rebuilt the head using stock valves, de-shrouded the combustion chamber along the outer combustion area of the valves, and trimmed the valve stems for even shim clearance after assembly. Rick has all the tools to perform all the critical checks and measurements on the bench while test fitting to the cam tray.
The head was ported, exhaust side only, both sides where then port matched to intake TBs and Euro M88 headers. The decision to only port the exhaust side was made by Rick. His experience with S14s and S38s proved that due to valve timing overlap S38s needed help on the exhaust side and would provide nice HP gains. The stock intake ports with larger pistons would then provide a higher fill velocity. Since the original build the Euro headers were modified to add 02 sensor bungs on each pipe so that high RPM port tuning can be performed. Note, this can only be accomplished with an engine management system that runs full sequential tuning and with features for individual cylinder fuel trims. The Vipec V88 can do this.
Head Pics
http://phil.infostreet.com/M5_Images/B3 ... o_Cams.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010024.JPG
Valves and Springs Installed After Being Pressure Pressure Measured and Shimmed
http://phil.infostreet.com/M5_Images/B3 ... 070038.JPG
http://phil.infostreet.com/M5_Images/B3 ... 070034.JPG
Valve Shrouding
http://phil.infostreet.com/M5_Images/B3 ... 030032.JPG
http://phil.infostreet.com/M5_Images/B3 ... 030031.JPG
http://phil.infostreet.com/M5_Images/B3 ... 030027.JPG
Head Mockup On Block
http://phil.infostreet.com/M5_Images/B3 ... 110045.JPG
Head Porting
http://phil.infostreet.com/M5_Images/B3 ... 210059.JPG
http://phil.infostreet.com/M5_Images/B3 ... 210058.JPG
http://phil.infostreet.com/M5_Images/B3 ... 210057.JPG
http://phil.infostreet.com/M5_Images/B3 ... 210056.JPG
http://phil.infostreet.com/M5_Images/B3 ... 210055.JPG
http://phil.infostreet.com/M5_Images/B3 ... 210052.JPG
http://phil.infostreet.com/M5_Images/B3 ... orting.JPG
Head After Porting
http://phil.infostreet.com/M5_Images/B3 ... 030033.JPG
http://phil.infostreet.com/M5_Images/B3 ... 070036.JPG
http://phil.infostreet.com/M5_Images/B3 ... 070035.JPG
Checking valve to piston clearance with light weight text valve springs
http://phil.infostreet.com/M5_Images/B3 ... 010026.JPG
S38 B36 Throttles Rebuild
http://phil.infostreet.com/M5_Images/TB ... 090339.JPG
http://phil.infostreet.com/M5_Images/TB ... 060345.JPG
http://phil.infostreet.com/M5_Images/TB ... 060344.JPG
http://phil.infostreet.com/M5_Images/TB ... 060343.JPG
http://phil.infostreet.com/M5_Images/TB ... 060341.JPG
http://phil.infostreet.com/M5_Images/TB ... 060340.JPG
http://phil.infostreet.com/M5_Images/TB ... 060336.JPG
http://phil.infostreet.com/M5_Images/B3 ... 030022.JPG
http://phil.infostreet.com/M5_Images/B3 ... 030023.JPG
http://phil.infostreet.com/M5_Images/B3 ... 030024.JPG
http://phil.infostreet.com/M5_Images/B3 ... 030025.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010004.JPG
http://phil.infostreet.com/M5_Images/S3 ... G_6986.JPG
http://phil.infostreet.com/M5_Images/S3 ... G_6984.JPG
http://phil.infostreet.com/M5_Images/S3 ... G_6988.JPG
Euro M88 Headers
http://phil.infostreet.com/M5_Images/B3 ... seup-2.jpg
http://phil.infostreet.com/M5_Images/B3 ... p_Nuts.jpg
Engine Assembly
http://phil.infostreet.com/M5_Images/B3 ... embly2.JPG
http://phil.infostreet.com/M5_Images/B3 ... _rods2.JPG
http://phil.infostreet.com/M5_Images/B3 ... weigh1.JPG
http://phil.infostreet.com/M5_Images/B3 ... weigh2.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010023.JPG
http://phil.infostreet.com/M5_Images/B3 ... lpump3.JPG
http://phil.infostreet.com/M5_Images/B3 ... lock-2.jpg
http://phil.infostreet.com/M5_Images/B3 ... _Block.jpg
http://phil.infostreet.com/M5_Images/B3 ... loseup.jpg
http://phil.infostreet.com/M5_Images/B3 ... Chain2.JPG
http://phil.infostreet.com/M5_Images/B3 ... igauge.JPG
http://phil.infostreet.com/M5_Images/B3 ... incaps.JPG
http://phil.infostreet.com/M5_Images/Bl ... ey_hub.JPG
http://phil.infostreet.com/M5_Images/Te ... 010005.JPG
http://phil.infostreet.com/M5_Images/S3 ... G_6973.JPG
Checking Piston Deck Height at TDC
http://phil.infostreet.com/M5_Images/B3 ... eight6.JPG
http://phil.infostreet.com/M5_Images/B3 ... ight10.JPG
http://phil.infostreet.com/M5_Images/B3 ... ight12.JPG
http://phil.infostreet.com/M5_Images/B3 ... Clay15.JPG
Checking Crank End-play
http://phil.infostreet.com/M5_Images/B3 ... 040168.JPG
Location Of Knock Sensor Port
http://phil.infostreet.com/M5_Images/B3 ... 250144.JPG
Oil Galley Cleaning
http://phil.infostreet.com/M5_Images/B3 ... aning3.JPG
http://phil.infostreet.com/M5_Images/B3 ... eaning.JPG
Cross Hatch Hone
http://phil.infostreet.com/M5_Images/B3 ... 070084.JPG
http://phil.infostreet.com/M5_Images/B3 ... nstand.JPG
Main Bearings Installed
http://phil.infostreet.com/M5_Images/B3 ... nblock.JPG
Crank Installed
http://phil.infostreet.com/M5_Images/B3 ... block2.JPG
http://phil.infostreet.com/M5_Images/B3 ... block3.JPG
Bench Testing Cam Lift and Piston/Valve Clearance
http://phil.infostreet.com/M5_Images/B3 ... Timing.JPG
Connecting Rod Balance
http://phil.infostreet.com/M5_Images/B3 ... lance3.JPG
http://phil.infostreet.com/M5_Images/B3 ... lance2.JPG
Crank Balance
http://phil.infostreet.com/M5_Images/B3 ... lance8.JPG
http://phil.infostreet.com/M5_Images/B3 ... lance1.JPG
http://phil.infostreet.com/M5_Images/B3 ... lance4.JPG
http://phil.infostreet.com/M5_Images/B3 ... lance5.JPG
http://phil.infostreet.com/M5_Images/B3 ... lance6.JPG
http://phil.infostreet.com/M5_Images/B3 ... lance7.JPG
Clutch Install
http://phil.infostreet.com/M5_Images/B3 ... 010031.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010039.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010038.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010037.JPG
http://phil.infostreet.com/M5_Images/B3 ... 010042.JPG
Oil Pan Mod For Oil Temp Sensor
http://phil.infostreet.com/M5_Images/B3 ... Gauge3.JPG
http://phil.infostreet.com/M5_Images/B3 ... Gauge6.JPG
http://phil.infostreet.com/M5_Images/B3 ... Gauge4.JPG
http://phil.infostreet.com/M5_Images/B3 ... Gauge8.JPG
Ceramic Coated Fuel Rails and Coolant Pipe.
http://phil.infostreet.com/M5_Images/S3 ... G_6987.JPG
RC Engineering Injectors
http://phil.infostreet.com/M5_Images/S3 ... G_6981.JPG
Cam Timing Sensor
http://phil.infostreet.com/M5_Images/S3 ... G_6979.JPG
New Vipec V88 and Custom Harness
http://phil.infostreet.com/M5_Images/Vi ... 180368.JPG
http://phil.infostreet.com/M5_Images/Vi ... 180369.JPG
http://phil.infostreet.com/M5_Images/Vi ... 180366.JPG
http://phil.infostreet.com/M5_Images/Vi ... 104007.JPG
http://phil.infostreet.com/M5_Images/Vi ... 104008.JPG
General Pecs - All the external parts have been either replaced new or rebuilt, painted and or ceramic coated.
* Custom S38 (3.7 ltr.)
* 95mm bore
* 86mm E34 m5 crank
* Metric Mechanic 11-1 forged pistons
* MM custom high-lift intake cam.
* E34 M5 exhaust cam.
* Fayhe B36 crank hub.
* M30 60-2 crank dampener-balancer.
* Exhaust cam sensor conversion from E34 M5.
* Rebuilt and Ported/polished head (exhaust side)
* Port-matched intake side for S38-B36 throttles
* RC injectors
* Slotted cam gears.
* Custom valve timing set by Paul Burke.
* E34 M5 Throttles and plenum box (new crinkle powder coat)
* S38 Euro headers, individual 02 ports added
* Oil pan modified for oil temp sensor
* New E28 M5 stock clutch & pressure plate
* Light weight flywheel from MM (14 lbs I recall)
* S52 cam chain tensioner
* All S38 B35 based accessories, hoses, external bits, internal bits are either new or rebuilt.
* Euro headers, throttle bodies, thermostat housing, water pump pulley, have all been ceramic coated my Enbee Performance.
* Vipec V88 programmable engine management available for additional cost.
The engine has been oiled and bench tested to verify oil pressure, but has never been fired. Then engines' final assembly and installation into a vehicle should be performed by someone who is specifically familiar with the S38 as well as with performance modifications. In addition, setting up and wiring custom engine management systems. All engine build steps should be verified by the installer prior to starting the engine. The seller takes no responsibility of engine condition, performance, horse power, non running condition or running condition. Potential buyers are welcome to inspect the engine, run a compression test, and pop the valve cover off, prior to purchase. Engine is located in Long Beach, Ca.
Thanks for looking. Any question please contact me by email or phone.
phil at infostreet.com
310-766-1923
2 5's and a 7
Re: Custom S38 and Euro 6 Speed Trans For Sale
Post by 2 5's and a 7 »
HOLYEEEEEEEEEEEEEEEEE SH______T! please let me win the Lottery Saturday.........
Philo
Post by Philo »
Guys, decided to go ahead and sell the E34 M5 6 spd separately. $6500.
http://www.mye28.com/viewtopic.php?f=4& ... 5#p1312995
Grande Royal
Post by Grande Royal »
Sent email concerning e28 M5 clutch/pressure plate also the MM flywheel. Never mind, all part of the package I realize.
Philo
Re: Custom S38 For Sale
Post by Philo »
Bumped this as I decided to sell the engine once again now that the S54 is humming away in my engine bay. I thought that maybe I'd stick this bad boy in an e30 or 260Z but decided not to get into another swap project. The S54 was too much trouble and very costly. It's all the little shit that killed my enthusiasm for swaps. Now thinking about the S55 M2 coming out later this year :)
Also, the 6sp Euro trans is gone. Selling just the engine and all the bits. I even have brand new Vipec V88 and harness that I'm willing to sell as well.
Let me know if anyone wants to chat about the S38. PM me or call - 310-766-1923
Odd, I don't remember the original post. Whatever, wow. :shock: I notice no price is listed, but I don't need to know, it's too rich for my budget, which is not a criticism, just an observation. Curious though, why did you start with a (relatively) basic M6 engine and not start with one of the unicorn S38B38 engines? GLWS!
milarsky
Post by milarsky »
PM
Philo wrote:Bumped this as I decided to sell the engine once again now that the S54 is humming away in my engine bay. I thought that maybe I'd stick this bad boy in an e30 or 260Z but decided not to get into another swap project. The S54 was too much trouble and very costly. It's all the little shit that killed my enthusiasm for swaps. Now thinking about the S55 M2 coming out later this year :)
Would this engine be SMOGable in California? It's probably irrelevant because as Mike alluded to, the lack of a price in your post = insanely expensive? ;)
BenGerman
Post by BenGerman »
This is awesome. It should be in the tech section and not in the for sales.
cek
Post by cek »
FIFU.
Now this can go in Eye Candy. :shock:
Philo wrote: Image
Head Pics
Valve Shrouding
Head Porting
Head After Porting
Euro M88 Headers
Engine Assembly
Oil Galley Cleaning
Cross Hatch Hone
Crank Installed
Crank Balance
Clutch Install
Cam Timing Sensor
Philo
Post by Philo »
CEK !! Dude, LOL.., I put links in the original post for a reason !!! But alas, we now have an image heavy mega-scroll-post that will no doubt get me banned from the group :)
Hi Mike, I posted this engine years ago and at the time was selling the engine and 6sp trans as a package. We'll, the trans is gone and I'm not up for another swap car project right now so decided to list the engine once again. Would love to see this engine go into a really cool e28 project, or maybe an e30. Te engine is so iconic. So back in the day when I found this engine my plan was to use a stock replacement S38 that I could put in my car when the original died. Well, it never died and I the M6 engine sat in my garage for years so I decided to rebuild it to a custom spec, and umm, in the process kinda went nuts. At least that's what the parts guys at the BMW dealering thought. I was on a first name basis with them for years. Had I found a B36 or B38 in the junk yard I would have done the same thing, build a custom engine. Price is left to private discussions. I prefer it that way.
PMs sent to those interested, thanks for looking.
Karl, shure it will pass, wink, wink... My S54 M5 passed, wink...
cek
Post by cek »
Tell you what: you copy my quote into a new post in eye candy so I can continue to get my rocks off and I'll edit my post here. Deal?
cek wrote:FIFU.
Eye candy? More like engine porn. Oh, we don't have a subforum for that yet. This might justify it.
Phil. No apologies on not listing a price, I fully understand. I admit, I am curious, as much to see how close or far off my guess might be because aside from not having a viable destination it's out of my price range. :laugh: I'm thinking, well, it kind of starts here, then he does that, and then this, then custom machine work, and... Any SWAG on what the HP numbers might be?
piperbrothers
Post by piperbrothers »
Can someone please buy this so I can stop trying to sell my children to the highest bidder
Philo
Post by Philo »
I've got a couple guys looking at the engine at the moment.
A couple things to consider with this engine for those still looking/thinking/dreaming. The engine is highly customized and has never been fired so the person who buys the engine needs to know their S38 shit or work with someone that does. You'll need to reconfirm all the basics, crank timing, cam timing, valve/cam clearance, torque on mains and rods, cam gears, you know, all the critical stuff. You'll need to run a programmable engine management system, adapt over the engine harness I have or build a new one. Setup the coil on plug arrangement, wire in an exhaust cam and crank sensors, program in the dual runner changeover for the E34 plenum, setup MAP sensor, IAT, throttle angle, etc.. Lastly, the compression is 11-1 aprox and the last time I did a compression test it was in the 230ish number with the cam timing set to a Paul Burke setting (cam gears are adjustable, cam location pins ground down), so careful consideration needs to be applied with the startup map as in fuel and timing.
In short, great engine for a race prep project or someone that has a really cool swap project in mind. I wish I had an E9 to put this thing into :)
Call or PM me with any questions.
Phil.
__________
310-766-1923
-- Added 20 Apr 2018 22:32 --
I got a call from someone from the Pacific NW area and wanted to look at the engine the weekend of the Long Beach Grand Prix. If that person is a member of the board please feel free to give me a call or email.
Phil
310-766-1923
phil@infostreet.com
Philo
Post by Philo »
Bumping the thread.., make me an offer..
this should be fun :)
heyrr
Post by heyrr »
Ever consider selling it on Bring a Trailer to the trigger happy nostalgia driven bidders? Have seen some odds and ends (parts/engines/wheels/drivers manuals) aside from whole cars sold there for lots o money.
austin8753
Post by austin8753 »
This is the engine my M5 deserves, but alas...
GLWS
