10 years ago I`ve bought cruise control and OBC II from american 528e with manual transmission. I unstalled this kit in my european 520i with M20B20. After installation cruise and OBC started working, except average fuel consumption.
Last week I tried to find the problem. I checked my instrument cluster (instant fuel consumption works on tachom as speedo work too). I changed it to another 2 clusters. I changed the chip from european 520 to 528e, also nothing changed. I checked wires from cluster to OBC - all of them were in working condition.
When speed is 0 and I reset MPG, I see ---- km/h. When I start going, MPG shows 39.5L. If I reset MPG, when the gas pedal is off and the engine is breaking, I see 0 L/km on OBC. As soon as I touch gas or RPM become idle, I`ll see 39.5 l.
I know, that OBC receives speed data, because average speed works.
Unfortunately, I don`t have another OBC to change it and to check. But could the problem be anywhere else?
Thanks.
MPG on OBC II doesn`t work
Re: MPG on OBC II doesn`t work
I don't have the ETM in front of me but I think the signal to the OBC comes off of the back of the tach and goes to the OBC through the connections labeled BLAU and WEISS. I would check that these are connected correctly and make sure there isn't another blue connector dangling somewhere on that harness. I have seen them were there are two different ones, you may have the wrong one connected to the consumption signal output from the tach.
Looks like the connections are on the speedo, but I suspect the issue is there regardless. I can't remember if I've ever seen a connection at the Grun/Green slot. I suspect Blau/Blue.
