I need to blank the rectangular hole or find a old fader
Any suggestions appreciated
I removed the fader control knob and need...
Re: I removed the fader control knob and need...
Put an unlighted window switch in that I have wired to control the lock unlock of the car.
Put in a two-button fog light switch which I use to control the antenna (my HU raises the antenna when on, not just when AM/FM is selected) and the second switch controls the fan for the amplifiers.
But the cover is in stock, that is a good thing.
Thank you for taking the time to help mejayjaya29 wrote: ↑Jan 23, 2023 11:50 AM 64111368498
https://www.fcpeuro.com/products/bmw-plug-64111368498
Can you post a picture of what you’re describing, please?Blue Shadow wrote: ↑Jan 23, 2023 12:27 PM Put an unlighted window switch in that I have wired to control the lock unlock of the car.
Thank you!
Turner Motorsports has a pic of the lighted window switch which for the door lock unlock will not work as it provides a path for electricity that the CLCU senses and it unlocks the car. Needs to be the early unlit widow switch. Site with the particulars is gone but the wiring goes to the CLCU mounted above the right side kick panel speaker.
The two button fog light pic provided by hubauer-shop.de
Both these switches fit the opening adjacent to the radio and in the US cars can replace the blank on one side and the fader on the other side of the radio.
The window switch is a momentary switch that I have wired to lock and unlock the doors.
The dual button fog light switch are latching on-off switches set up for the antenna and the fan in the trunk for cooling the amps.
Let me see what I have York! I might have the fader/switch you need. I just no longer have an e28
Mike
Mike
The blank was available at dealer in one day
Thanks everyone
Thanks everyone
That antenna idea is good one.Blue Shadow wrote: ↑Jan 23, 2023 12:27 PM Put an unlighted window switch in that I have wired to control the lock unlock of the car.
Time to hit the switch stash in the gayrage.
