Neutral Start Switch Replacement?
robertodonnell
Post by robertodonnell »
Hi guys,
I have the 4HP22 shifter lever on the bench, and I am trying to work out how the hell to get it apart to replace the inhibitor/neutral start swicth. Can anyone give me a run down or a link to do this?
Cheers,
Robert
Aldo525
Re: Neutral Start Switch Replacement?
Post by Aldo525 »
hello, you mean this:
I'm not sure it really comes apart to replace the parts you're looking to replace, it's more of a switch assembly.
But I'll add this, on a 3HP22 E23 I used to have, I was having problem with the neutral safety, took a can of contact cleaner and just kind of hosed down at the opening as best I could while working the lever back and forth. Worked perfectly, I never had problems with it again.
