My 518i has mechanical steering and in the upper part of the case there is a plug (11 in the image) that I assume is to fill it with oil... but what kind of oil? SAE 80/90???. It was not an option in the US e28 but maybe some e12 or e21 had it??
Thanks
Mechanical Steering box oil type
Re: Mechanical Steering box oil type
Yes, SAE 80-90 is what I've used in other cars. I did actually have a '69, E3 with non power steering, but I changed that right away.
Not sure it's right, but I suspect it is, but I'd use a GL5 hypoid oil, not the GL4 that gets used in manual transmissions. It's thicker and stickier so to speak.
Thank you Mike!!. Just refill or some kind of drain before the new oil??...can't see any drain plugMike W. wrote: ↑Dec 05, 2022 7:53 PM Yes, SAE 80-90 is what I've used in other cars. I did actually have a '69, E3 with non power steering, but I changed that right away.
I don't think there is a drain plug, I'd just refill.
Oil detail, capacity and oil filling level are shown in the E12 handbook.
Its very important to not overfill the steering box.
