Is the correct part number for the control arm w/ bushing:
LEM-1052701 & 1052801??
This is for OEM pn: 31121132341 & 31121132342
Lemforder control arms w/ bushing - part numbers
Re: Lemforder control arms w/ bushing - part numbers
I don't recognise those part numbers - Where did you find them?
Here's what I know from research done for my '86 E24 with an E28 chassis.
https://www.realoem.com/bmw/enUS/showpa ... Id=31_0016
31121139991 Front Lower Control Arm (Wishbone) Left - Steel OEM
OR: 31121139987 Front Lower Control Arm (Wishbone) Left - Aluminium (E24 M6, E32, E34)
OR: 31121138477 Front Lower Control Arm (Wishbone) Left - Spherical (E31)
31121139992 Front Lower Control Arm (Wishbone) Right - Steel OEM
OR: 31121139988 Front Lower Control Arm (Wishbone) Right - Aluminium (E24 M6, E32, E34)
OR: 31121138478 Front Lower Control Arm (Wishbone) Right - Spherical (E31)
31121124622 Front Lower Control Arm (Wishbone) Inner Steel Rubber Bushing Only x2 (Usually included with the arm)
31121132353 Front Upper Control Arm Left
31121132354 Front Upper Control Arm Right
OR: 31129058819 Front Upper Control Arm Meyle HD (Heavy Duty) Rubber Bushing x2
OR: Moosehead Engineering Spherical Front Upper Control Arm Bushing x2 (UCABs)
More info here:
https://bigcoupe.com/phpBB3/viewtopic.php?t=33016
More info here:
