are E 28 window motors all the same?
asking for a friend TIA
Re: are E 28 window motors all the same?
The early ones had a different plug set up. 82/83. But you can get around it.
Andy
Andy
According to realOEM there are separate part numbers for each door, front left and right and rear left and right, but for a given door the same motor is used on all e28s.
Yes and no, same motor, but the early ones plug is different. The plastic piece that is attached to(pushed on) the motor, on the later style(after 1982) is glued on it the motor and you have the plastic plug that goes on to the harness.stuartinmn wrote: ↑Apr 07, 2022 8:00 PM According to realOEM there are separate part numbers for each door, front left and right and rear left and right, but for a given door the same motor is used on all e28s.
Andy
South, my friend Walter needs a drivers door motor for his '87 528e He doesn't need the regulator just the motor.IIRC I have a regulator with a motor somewhere in my shed.No clue as what it was. I can rob B6II for it but it would be simpler to buy one from you. I want to keep this campaigner on the road. Haz?
I will check tomorrow. I think I do.a wrote: ↑Apr 07, 2022 9:10 PM South, my friend Walter needs a drivers door motor for his '87 528e He doesn't need the regulator just the motor.IIRC I have a regulator with a motor somewhere in my shed.No clue as what it was. I can rob B6II for it but it would be simpler to buy one from you. I want to keep this campaigner on the road. Haz?
Andy
Sorry all out.
Andy
Andy
Thanks Andy. I have 1 or 2 places to look or I could just start parting B6II.
I have a bunch of them but not sure if any are for the e28. Got a pic?
still looking
I have a set of 4 power window regulators with motors and heck I even have a set of real crank window regulators . Shoot me a message if interested IM IN Canada will ship
