Opening the 265
Re: Opening the 265
I like your thinking haha
try to make a "circlip" that goes around most of that lip and use the puller on that if you can
Re: Opening the 265
Work in progress
Have to wait until tuesday to see if it works with the help of
propane torch.Suspence is unbearable.All bets are off.
Re: Opening the 265
Re: Opening the 265
Yes, one of those, "don't try this at home" things.
Re: Opening the 265
Woohoo! Go go go!
Rust Bucket wrote: ↑Sep 04, 2021 1:37 AM Work in progress
Re: Opening the 265
Done finally
Propane helped a lot
Pressed out bearing,was pretty easy
Taking measurements for next project
Re: Opening the 265
Awesome! Now you can finally compare the internals of the Getrag 280 vs the 265/6!
Looking forward to this as my spare 265/6 has some input shaft play.
Re: Opening the 265
Now THAT's a serious tap. I think I see 1/2 NPT, but it looks bigger than that.
Re: Opening the 265
1 inch and a half NPT
Re: Opening the 265
Some action to come
test5 been very,very patient
Re: Opening the 265
Most impressive, all of it.
But I've got a problem with it. I can't figure out how I would ever replicate it if I needed to!
Re: Opening the 265
Duplicate, never mind.
Re: Opening the 265
I plan on making a small batch.The whole thing with the pipe cut to lenght so you screw it on and put your puller on it.
test5 will receive first one and report.Once it's proven to work as anticipated I'll make other ones,limited offer.
Hope it work great,already bought the material(mild steel) and metal aint cheap these days.I dont see how it could go
wrong tho.I rushed to have the 2nd side done before holydays but Omicron cut the grass under my feets
Re: Opening the 265
The prototype is here.Small details will be taken care of and test5 shall receive it soon.
Re: Opening the 265
7 kits will be availible
I'd like these to go to peoples who will put it to good use and contribute to our common 265/6 knowledge.
I engage myself towards buyers of this kit to build future tools needed as we get deeper in the transmission.
Let me know if your interested
Re: Opening the 265
I am in South Africa. I am busy assembling my Getrag 265/6 but I am clueless where two 8mm ball bearings fit into before I fit the output cover. Do they fit loosely into the selector shaft holes for the selector shafts 1&2 and 5&R behind the 8mm cross pin? I know that three of them fits into the middle casing with springs for the detent of the shafts.
17 Ball D=8MM III 5 07119986280 $0.66
Re: Opening the 265
Hi Andre, quite the timing.
I cant awnser your question as of now. But I am
back at it and hope for knowledgeable guys to
join us. Surely someone might have the awnser.
Posts and pics to come
Re: Opening the 265
Some pics of me using the new tool to open a Getrag 265.
It worked flawlessly.
6 kits are availible. (Including threaded rods and T's to pull inner race as showned prior)
Asking 150$
Asking 150$
Re: Opening the 265
PM'd
Re: Opening the 265
Looking great. I'd be interested in a set. PM sent.
