Good morning forum,
I have a 1986 E28 528i auto, the old girl has developed a strange intermittent starting fault, after running for some time getting upto temperature, If i pop to the shops or go for a walk (10-20mins), when I return to the car it wont crank? Totally dead. Popping the bonnet you can hear the fuel relay click, but nothing from the solenoid or starter. Dash lights up as usual and dims when you try to crank. Ive tried starting in P and N, no response.
I have to pop the bonnet and leave for 30/40mins, then suddenly starts fine?
Car has new battery and has had a starter motor & solinoid replacement 2yrs ago (1000miles).
ideas / experience welcome!
thanks in advance.
E28 528i - M30 Intermittent Hot No Crank
Re: E28 528i - M30 Intermittent Hot No Crank
Try whacking the starter motor with a broom handle. If it magically starts, you have your answer.
brass rod works well too, if you don't have a broom handle.
Never thought of that . . . been using it since I was a kid, yikes
I always used the tire iron from the trunk to whack the solenoid.
If you have to replace it again get an e34 gear reduction starter. Much better I believe.
And when giving it a wack doesn't work you grab a screw driver and bridge the connection form the battery cable to the starter motor winding. Sparks may fly for sure but if the starter motor is good and the solenoid is not pulling in it should start the car. I've had to do that but I've not had to do that on my cars with manual transmissions. I like that you can very easily push or roll start these cars.
When these cars were new I believe there was a rubber boot over the bare cable and starter connections so you couldn't just bump into those and get a short. But I'm not sure. There is no cover over the battery + on my car and maybe there never was. In any case the starter is tucked up under there so well who will get into that unless determined. Never even considered it when changing oil. I think you would have to work at that. The alternator on the other hand should have a rubber boot on it.
