quick question, oil pump
four2zerohero
Post by four2zerohero »
Is shimming an oil pump better than leaving it as is if the chain has wear? I am replacing my oil pan gasket and as you know the potential for mission creep is high. I'm on a tight budget, and it seems like replacing the chain requires replacing the sprocket which is a special order item.
is shimming the pump better than nothing?
Thank you
BMWCCA2
Re: quick question, oil pump
Post by BMWCCA2 »
I think you should shim the pump regardless of whether or not you replace the chain.
A couple of years ago I replaced the pump and shimmed it but did not replace the chain or sprocket. Seems to be working fine. Oil-pressure lamp goes out almost before the engine catches!
SlickDizzy
Post by SlickDizzy »
If you are in that far, I would highly recommend you spend a few extra minutes to split the oil pump halves and replace the “wear plate” inside, which is a sacrificial piece meant to prevent housing wear. Between that and the shimming you should buy yourself a fair amount of time until you can do the whole job.
#12 in the attached diagram, they cost a whole five dollars from BMW.
https://www.realoem.com/bmw/enUS/showpa ... Id=11_2122
Replacing the pressure relief spring (#21) is also not a bad idea and is very quick and easy to do, though probably not as necessary.
four2zerohero
Thank you gentlemen,
BMWCCA2 wrote: Nov 12, 2020 9:47 AM I think you should shim the pump regardless of whether or not you replace the chain.
so would a couple of the 1.0mm shims stacked upon each other work? i cant find anywhere that sells the 3.0mm one,
four2zerohero
SlickDizzy wrote: Nov 12, 2020 9:54 AM If you are in that far, I would highly recommend you spend a few extra minutes to split the oil pump halves and replace the “wear plate” inside, which is a sacrificial piece meant to prevent housing wear. Between that and the shimming you should buy yourself a fair amount of time until you can do the whole job.
Thank you, this is the mission creep i could afford. May be a silly question, but should I still lap the housing halves to ensure they're true?
SlickDizzy
four2zerohero wrote: Nov 12, 2020 11:19 AM
I wouldn’t bother, the softer metal wear plate acts as a gasket of sorts.
four2zerohero
SlickDizzy wrote: Nov 12, 2020 11:44 AM
good to know
thanks again
four2zerohero
okay, another question.
I've got my pump removed and on the bench and disassembled. It turns out it already had one set of shims installed. My question is can i stack up various 0.01mm shims to take up the slack? will the oil leak through them if i do? I ask about the 0.01mm shim because i cannot seem to find the 0.03mm one anywhere.
thank you.
WVe28
Post by WVe28 »
Yes you can stack them. I ended up with three each on mine.
WVe28 wrote: Nov 17, 2020 11:59 AM Yes you can stack them. I ended up with three each on mine.
Was that before or after the "quart erry hunnert" problem?? :rofl:
All kidding aside, did you figure out what what wrong?
