I purchased a 6 piston caliper of ebay but got the wrong part delivered.
Already bought another one which should arrive some time next week.
I still need to confirm the physical differences between the 330 and 350mm setup. The pads are different, the bolt locations are different, but potentially the housing might be the same.
I'm still aiming to have the M7 equipped with Cayenne calipers, E34 MC, 348/345mm rotors and the vacuum booster setup at the Vintage.
I would also like to bring some of the other sets as showcases.
Agreed, they are easily available.q20v wrote:If you want to sell me a set before your website is up and running I'd love to help out in that respect. You've invested a ton already, I don't mind investing in your brackets if it helps confirm another platform. I've been eyeing 986 rear calipers on eBay lately and there's definitely no shortage!
There is also a nice set of Turbo calipers all around for about $400 OBO! Still a very good deal. The last set of used E31 calipers sold for double that.
It will be a while before I have those brackets ready for serious testing.
I really want to take the first set out myself and give them some good testing. Again, we are not talking about some fancy add on.
This is brakes. Failure of this product can cause serious harm to people on the road.
Thanks for sharing all your infos, it's great to see that I'm not the only one out there with those thoughts.scarey013 wrote:I’m glad this thread came up. I’ve had a set of 996 calipers for a few years and have been planning on putting them on my e28. A good friend of mine pointed out that the bias would likely be way off, so I started making spreadsheets. Oh joy.
I hope at some point this can be the go-to thread for big brake upgrades on our platform.
My spreadsheet by now has about 15 worksheets with different calculations.
Good information in the M3 rear rotors. At this point, I don't see a good use for them but I'll add them to the list for sure!
Sounds good, I'll keep you in mind. I have an E23 myself. At this point I would hate to tear a strut out of the car, but I have a good lead to a spare set of struts to take my measurements outside the car.skeeter_nohustle wrote:Im in Cincinnati and im the proud owner of beautiful 1985 BMW 735i E23 if you need a donor car for test fitment let me know i can make the drive to you sir. Besides i would love to upgrade my brake system lol
Thanks again for all your inspiration. I went through your thread a couple of times to get everything that you already collected.Philo wrote:Great work and really happy that someone picked up on this project. Looks familiar - http://phil.infostreet.com/M5_Images/99 ... lipers.JPG
I'm running the Porsche 996 fronts with E34 M5 rears on a 528e vacuum booster. Visually I like the look of the big calipers and rotors but to be honest I had better stopping power with the original M5 brakes on hydro-boost. I think my issue is not enough vacuum, currently using a 528e booster. Any ideas on how to up the vacuum let me know.
Thanks Ben, keep it up !
P.
Too bad your project died after your car!
Vacuum is something I would consider switching over too as well. How did you make it fit in your M5, do you have detailed pictures?
From my measurements it would be extremly tight.
One option could be the E34 booster?
Edit: I believe the ITB setup might be the culprit. It is known to cause lower vacuum pressure than the single TB setup if I'm not mistaken.
Where do you get your vaccuum?
I will try to call you next week.
