demetk wrote:The hose specs above are for the 18" wide x 16" high condenser that has a #8 inlet port and a #6 outlet port.
Note that because the compressor on the M5 will need to be clocked at 90 degrees the hose lengths and clocking angles of the fittings will change.
If you're hesitant on ordering made up hoses from the specs above, I would suggest you buy the fittings and hoses separately, cut the hoses to length and loose fit the fittings in place. Once you're satisfied with the fit, mark the fittings to the hoses and have them crimped at a local a/c shop.
1.) on the large suction hose #10 all they have available is the BL1313-3 it states it is a suction port and not a charge port. Any Ideas here? Im doing R134a
2a.) Also not seeing a 135 degree o ring hose without some sort of discharge or sucton port on it.
2b.) This hose is available without issues!
3a.) Didnt't even attempt because I am not going to attempt to braze
3b.) ColdHose is cosidering this #8-#6 or #6-#8?
