M70 starter on an M30
My friend has an e34 535i and he heard you can use a m70 starter. He's got one on the way, im looking forward to seeing if it works.
Just putting this out there, more to come. No performance gains obviously, but they do sound amazing.
In case you're thinking it must be more heavy duty, maybe not. Remember you are only cranking over one cylinder at a time (ok, somewhat more especially with a 12) and 3.5 cylinders are larger than 5/12. As an illustration of that, early M30s used the same starter as 4 cylinder M10s, a 1.0HP one. Later M30s used 1.2 and later M10s 1.1, so still not much difference between the 4 and 6 engines. And for trivia sake, yes, they are interchangable. (M10 and M30 that is, I have no idea about M70s)
Re: M70 starter on an M30
Bump.
I've read a few articles about this. But not as much info as I expected
And I'm looking to do the samething
Any reports about a damaged flywheel in the process? If not I gonna do this upgrade. Looks just to be a bolt and go affair
Re Bump.
For anyone else trying to do this.
It works. Just Bolt and go. The m70 starter has two terminals on the body of the starter. I used one as an additional ground to the starter. Do you need too? Prolly not. But it doesn't hurt
Interesting. How big is it? Does it have a PS (HP) rating on it like some do? Advantages/disadvantages, other than if you tried to use it as a core.
It is definetly bigger. It's just a more powerful starter. You should have faster start ups theoretically
This is the only pick I have of it on the block. Engine already installed in the car.
The power rating was on the literature in the box. I got an autozone version. Lifetime warranty with unlimited replacements. And it's only 155 plus tax
http://imgur.com/a/fFtqIXO
http://imgur.com/a/3Dcdkx3
Only Negative of using the m30 Starter is that because of its size, the intake manifold will need to be removed as you can no longer hit the top bolt straight on. The angle is too sharp to just use extensions. So it's kinda sad
Just a thought, somebody mentioned the m70 starter “sounds cool”, the reason v12s sound cool, as in spaceship smooth, when cranking is because there is more than one piston on compression stroke at a time, so the transition between cylinders is seamless, unlike a lesser cylindered engine. I imagine the m70 and m30 starters both sound like electric motors in isolation.
I can confirm
M30 with the v 12 starter sounds the same.
The v12 itself sounds cool starting up
