what fixed YOUR hot no start ?
yeah yeah another no start when hot post.
YES i've read the other threads but they all sort of seem to just fizzle out without really saying what the issue was, except the DME.
on my '84 528e, it cold starts amazing. you look at the key and she fires up, it'll idle all day long holding perfect temp. blows cold ac, heat comes and goes in waves... might have air bubble, idk.
it will NOT hot start to save it's life. ive replaced the O2 sensor, cap and rotor, plug wires (plugs too), coil,
just did a new thermo sensor (2 prong), i guess im going to do those two bellhousing sensors next then the DME if it's not them?
it has a brand new battery and cranks super fast. it's a shame bc it cold starts so well and runs fantastic. im going crazy trying to figure this out.
so what fixed Your hot no start issue on your e28 ?
also in today's day - 2023, what ecu repair would you send your dme to ?
thanks!
thanks!
Re: what fixed YOUR hot no start ?
Maybe one of this: (Haynes)
Some fuel issue, pressure regulator????
so i have a brand new air filter, new fuel filter, new inline pump and in tank pump.
my regulator isnt broke (no fuel in vac line) but i suppose that doesnt mean that it's not bad. again, if it was bad would it cold start perfect ?
CTS bad or possibly unplugged.
A 535 not an eta, but mine had a very difficult to start when warm, condition when I got it. It would restart if it was right away, but if I went into a store for a few minutes it was hard to start. Easy clue was the odor of gas when it did start. My injectors were leaking and it was flooded. When cold, the extra gas wasn't a problem because it was cold. If I started it back up right away, it didn't have time to leak enough, but give it a few and it was trouble.
Long shot, but easy to test with the sniff test.
My car was behaving badly hot and even random stumbling at times once running. Cold starts were great but there was still occasional stumble as it warmed up. I suspected the cold start injector so I disconnected that fuel line and plugged it. Problem solved.
If the CSI leaks the longer it sets the more fuel gets into the intake making a hot/warm start more and more rich. I needed to crack the throttle quite a bit on warm/hot starts so it could clear itself out faster. If I didn't apply some throttle it may not start and I feared it might foul the plugs.
Since I was into it for the first time in a long time I realized I also had new plugs, cap and rotor to put on it so I did. Cold starts are not as quick now but otherwise it's been running like a champ ever since.
My old 535 gets very little attention these days and this problem had been getting worse and worse for at least a year or more as I was just lazy about it as long as it would go. When I do work on the M30 I still appreciate how simple these systems are to troubleshoot and fix. But the Haynes stuff above is probably not worth quoting.
I also had some fuel smell but that turned out to be no more than a weeping connection on the rail which I tightened.
CTS is cold start .... solinoid ?
if i didnt mention it, i bypassed my Cold start valve as mine was stuck open and it clearly does Not need the CSV for cold starts at all. fires right up, ildes perfect.
i also left out i had my fuel injectors cleaned out and tested. that was my main issue when i first got the car with it not running.
with that being said im leaning towards DME, which is odd... but im not sure what else to check
[/quote]
CTS: Coolant Temp Sensor....this sensor gives the temp data and signal to the DME. Maybe bad readings when engine is hot. #13 in the picture, OEM 13621357414
[/quote]
Another clue taken from a german forum:
"Swap the main relay....on the side of the fuse box. My e28 & e30's did the same thing. Typical that it sh**s the bed when hot."
CTS: Coolant Temp Sensor....this sensor gives the temp data and signal to the DME. Maybe bad readings when engine is hot. #13 in the picture, OEM 13621357414Aldo525 wrote: ↑Mar 24, 2023 7:44 AM CTS is cold start .... solinoid ?
[/quote]
i just replaced # 13, i didnt think a coolant temp sensor affected hot starts. pretty cheap, i'll throw money at that
yes i did swap relays already. no luck
Sh00bs wrote: ↑Mar 24, 2023 10:26 AMCTS: Coolant Temp Sensor....this sensor gives the temp data and signal to the DME. Maybe bad readings when engine is hot. #13 in the picture, OEM 13621357414Aldo525 wrote: ↑Mar 24, 2023 7:44 AM CTS is cold start .... solinoid ?
CTS sends the signal which initiates the fuel/air mixture cycle.
If you're getting a cold reading when hot you'll get a flooding condition.
A no connection to the sensor sends a cold signal, thus my "possibly unplugged" comment.
The CTS has little to do with starting and more to do with how it runs throughout the cold to warm transitions. A new CTS is not a bad idea as they can get out of spec. But hot running would be terrible if the CTS were the real problem, meaning as it warmed up it would get worse and worse. Unplug the CTS when it's warm and see how badly it runs. So I don't think this is it unless it begins to run terrible as it warms up and then will not re-start.
tn535i wrote: ↑Mar 24, 2023 6:05 PM The CTS has little to do with starting and more to do with how it runs throughout the cold to warm transitions. A new CTS is not a bad idea as they can get out of spec. But hot running would be terrible if the CTS were the real problem, meaning as it warmed up it would get worse and worse. Unplug the CTS when it's warm and see how badly it runs. So I don't think this is it unless it begins to run terrible as it warms up and then will not re-start.
I'm no expert, but poor running as it warms sounds like TTS.
Doesn't the TTS have the 3 signals function as coolant warms.
A friends S38 was exhibiting the no-start when hot which he chased for weeks. Finally out on a drive when it happened we started checking sensor connections. When we came to the CTS the plug was laying squarely on top of the sensor. After plugging it in, a few long cranks later we had black smoke upon start-up and an ///M5 back in the chase, thus my comments.
Thermo Time Switch only affects the cold start valve and only has the potential to do so while cranking. It's emphatically a cold start device.1st 5er wrote: ↑Mar 24, 2023 6:34 PM
The coolant temp sensor does affect running at all temps.
Now I know.Mike W. wrote: ↑Mar 24, 2023 6:51 PMThermo Time Switch only affects the cold start valve and only has the potential to do so while cranking. It's emphatically a cold start device.1st 5er wrote: ↑Mar 24, 2023 6:34 PM
Gracias!!!
A new main fuel pump, the check valve inside was bad.
It would start just would take about 5 seconds or so when hot, but not hot. 30-90min hotish restart.
CTS let's the ecu know how much fuel to use based on temperature.
I had an M30 that started great cold but the idle would start going up as the engine warmed to eventually idle at about 1200. It would not hot start. There was a bad connection at the CTS, cleaning it fixed the problem.
But these cars were 'repaired' by BMW if one complained about a rough idle back in the day. The solution was to install a resistor in the CTS circuit, usually in the boot of the connector to tell the car it was a bit colder than it really was, a bit more fuel but not much, just enough to cure the rough idle. If this resistor install has failed open the CTS is not talking to the ECU and in the M30 would have great cold start, high warm idle and difficult or impossible hot start.
talking to some friends, they said they had the same issue's and a crankshaft position sensor fixed it. so i ordered one of those.... i havent tested the ohms when cold (or hot)
we'll see. it's wild. it runs so great when cold, and will run for what seems life forever after firing up. perfect temp, happy as ever. the second you turn it off and try to restart, just cranks.... cranks cranks cranks so weird.
WELP.
replaced the CPS - crank position sensor. it was the LOWER of the two on the bellhousing. no more hotstart issues!
it would run forever when starting cold, fully warmed up, longest i ran it was about an hour and a half.... if you shut it off, INSTANTLY it would Not start back up.
CPS replaced, boom good to go! thanks all for the insight. hopefully this thread will help someone else in the future
That makes sense. One of them, the reference sensor I guess, is only used on start up. Literally you can unplug it once it's running and it will continue to run, because once it's running the speed sensor is counting the teeth on the flywheel to fire the ignition and pulse the injectors.
Long story I won't bore you with how I found that out.
Thanks for posting the solution.Sh00bs wrote: ↑Apr 04, 2023 6:48 AM WELP.
So many here and abroad, other forums, don't report the fix.
I am late to check back. Good catch and good you report back. Now that I hear it this makes perfect sense.
I had a component that would fail on another vehicle when hot. Ok if it was running but no restart. I had to poor cold water on it to get the car to start again a few times until I got the replacement.
