Replaced thrust arms and control arms, a job which would have been exponentially easier if I had a two post lift. Preloaded, loctite, all that jazz. Just waiting on tie rods to come in. Laying on my side, my foot holding one wrench while I pull on the torque wrench, strut housing in my face, yeah. Good times.
the other day I covered the hole in the driveshaft tunnel from cutting the factory handbrake out.
today I drove it to work for the first time in years. also just ordered a new fuel sending unit gasket and longer e24 hood struts since mine are bent and junk. from FCP Euro with the lifetime warranty. only 12 bucks a piece for the hood struts.
Pulled my rear subframe yesterday. the harshness of a welded diff coupled with a period of time where my diff bolts had come a little loose cranked the frame on the lower diff mounting points. it will get stitched up and reinforced with condor plates.
also threw on the e24 hood shocks and man, what a difference. a no brainer if yours need to be replaced Anyway.
I am waiting on parts for my 528e manual trans swap, so I threw in my M5 steering box, since I have the steering column out. Figured I would get ALL of the ATF out of the car at one time. I found a new p/s filter and enough new hoses to replace it all. Fuel hose is BMW, so that probably needs to be replaced. I swear the oil pan gasket was original. New gasket coming for that also. Also found a long tear in the throttle body boot. Probably a cause of an idle issue that is getting worse. Also installing Powerflex subframe bushings and might as well put in an LSD, while the driveshaft is out. Does it ever end?
Shift rod. Turns out the bushings and linkage are good --- I figured as much that when the PO did the new shift boot and such that he had those done. It was the motor mounts that did me in on the linkage I'll bet. I also forgot that we had done the guibo months ago because we happened to have one so now it's just down to the CSB that I'll get to in the next couple weeks as there is a mild shudder.
PS: We didn't drop shit except a few curse words LOL.... Country livin' we found a long u-shaped tool and just kept at it till we got the top circlips off.
https://www.facebook.com/KingCast/video ... 7385715632
Water pump. Minor coolant leak had been evading me but I finally caught the water pump in the act, leaking from the weep hole. Replaced it with a HEPU brand aftermarket pump. Straightforward job, used the Permatex 80019 non hardening sealant on the gasket.
Redid the color on the rear deck (carpet behind the rear seats). See below and after. It's lighter in the middle as the carpet was basically fully disintegrated in that area. Originally color is nutria (brown).
drove my M5 to Redmond, WA, yesterday. my back is screaming at me, but the car did very well. this was the longest consecutive trip i've taken in the thing.
You should have reached out and stopped by!austin8753 wrote: ↑Sep 28, 2020 12:03 PM drove my M5 to Redmond, WA, yesterday. my back is screaming at me, but the car did very well. this was the longest consecutive trip i've taken in the thing.
Well, completed yesterday, drives great, but massive trans leak from the rear. I replaced the shift shaft seal, so rear seal has been ordered. Super fun.dsmith wrote: ↑Sep 07, 2020 9:43 PM I am waiting on parts for my 528e manual trans swap, so I threw in my M5 steering box, since I have the steering column out. Figured I would get ALL of the ATF out of the car at one time. I found a new p/s filter and enough new hoses to replace it all. Fuel hose is BMW, so that probably needs to be replaced. I swear the oil pan gasket was original. New gasket coming for that also. Also found a long tear in the throttle body boot. Probably a cause of an idle issue that is getting worse. Also installing Powerflex subframe bushings and might as well put in an LSD, while the driveshaft is out. Does it ever end?![]()
Replaced the shift shaft seal again and the rear trans seal and no leaks! Happy day. Just received my cheap leather shift boot and then I can call the conversion completed.dsmith wrote: ↑Sep 28, 2020 7:14 PMWell, completed yesterday, drives great, but massive trans leak from the rear. I replaced the shift shaft seal, so rear seal has been ordered. Super fun.dsmith wrote: ↑Sep 07, 2020 9:43 PM I am waiting on parts for my 528e manual trans swap, so I threw in my M5 steering box, since I have the steering column out. Figured I would get ALL of the ATF out of the car at one time. I found a new p/s filter and enough new hoses to replace it all. Fuel hose is BMW, so that probably needs to be replaced. I swear the oil pan gasket was original. New gasket coming for that also. Also found a long tear in the throttle body boot. Probably a cause of an idle issue that is getting worse. Also installing Powerflex subframe bushings and might as well put in an LSD, while the driveshaft is out. Does it ever end?![]()
It was 88F outside, so not blistering. AC was upgraded with Austin's kit
Pulled sport seats, consoles and carpet out and vacuumed tired worn out deadening material and put new foam in. Replaced with new carpet. Pulled the dash which looked as if an IED had gone off inside. Started swapping out items onto new dash. Pics to come.
Took all 4 door cards off and cleaned/re-greased the runners and pivot points. Also greased hinges, no more squeaks.
What did you use for the new foam and how did you install it? When I pulled my carpet, it seemed like the carpet and foam were one piece
Rhetorical question.dsmith wrote: ↑Sep 07, 2020 9:43 PM I am waiting on parts for my 528e manual trans swap, so I threw in my M5 steering box, since I have the steering column out. Figured I would get ALL of the ATF out of the car at one time. I found a new p/s filter and enough new hoses to replace it all. Fuel hose is BMW, so that probably needs to be replaced. I swear the oil pan gasket was original. New gasket coming for that also. Also found a long tear in the throttle body boot. Probably a cause of an idle issue that is getting worse. Also installing Powerflex subframe bushings and might as well put in an LSD, while the driveshaft is out. Does it ever end?![]()
Resprayed those weird carpet inserts on our door cards, and I really like how it turned out. Was super easy to do too. Just used SEM Color Coat spray paint that's made for carpet, viny, etc. Similar to what I did for the rear deck.
nice little cheap improvement!
I used a sound proofing material similar, Kilmat 80m. My carpet was an older, non-carpeted back. I'm a little disappointed because it does not fit perfectly. Seeing as how its an OEM carpet, I'm sure its something I'm doing wrong, but its not fitting onto the door and foot dead pedal areas like i'd like.
I heard my horn for the first time in my 2 years of ownership. Yesterday morning I heard it buzzing randomly out the blue so I pulled the battery. The car came with an aftermarket steering wheel and an inoperable horn button.
Rebuilt my AFM ..!! Much better -
We need a drive soon ...!!!
Got the registration renewal last week:
So long, 2020!
(Don't let the door hit you in the a** on the way out)
So long, 2020!
Today I replaced the "window guide" rubber in my passenger rear door. I snagged the apparently NLA part off a junk yard car a few weeks ago. The one in my car was badly cracked due to sun damage. The junk yard part is in remarkable shape, considering it is probably original too. Anyway, swapping the guide was also remarkably easy and rewarding. I think I paid $6 for the part. I have new guides for the other 3 doors & I think I've spent $300 combined for them. I'm pretty sure putting them in won't be quite as satisfying...
Happy Holidays y'all
Cool. You've been talking about this for some time haven't you? Wondering if it will bring the rumored lack of required biannual smog test. Regardless, looks good, albeit not quite as good as the euro plate underneath.
Diverging a bit... I remember when I was in college and a cousin bought a '47 Cadillac. Nice car, good to very good condition. At the time it was 25 years old and therefore considered an antique car. It was neat, but it was clearly old. He made a couple of trips of several hundred miles in it and made it home, but there would have been no thought of going cross country in it. Contrast that to E28s with an average age now of 35. Sure, they're not new, but a well sorted, and I don't mean pristine low mileage or fully restored, just in good shape, would not give me a moments pause about a cross country trip. Or the return trip. OK, the front end might start to shimmy, but oil or coolant shouldn't be a problem, except maybe a quart of oil, even 6K miles, and if it was the check control would let you know.
Cars are profoundly better and longer lasting than they used to be, but how many people would be comfortable in any pre 2010 car cross country. And back? Hell, probably pre 2015 would have most people cars at their limit, comfort wise.
I actually did the plate switch back in 2014: viewtopic.php?f=2&t=122801&hilit=historic+plates
While it did allow me to stay under the CA DMV's radar for quite a few years (almost 6), they finally caught up with me for the 2020 renewal. I guess this was a precursor of what 2020 had in store for us.
So after some consternation about alternate registration options, I broke down and created a compliant exhaust & emissions system consisting of my old exhaust system, a new DEC Cat I had in storage, a new O2 sensor, charcoal canister (for visuals only), and an 059 ECU that goes in for the SMOG test, then promptly comes out. The exhaust system hangs from the ceiling of The Hangar waiting for the next time I need it.
It's still not a full-proof method since (supposedly) the CHP is performing rolling emissions tests at their discretion at the behest of the DMV; these plates might start to feel like a target. But I am less concerned around Los Angeles as the CHP has WAAYY more to worry about.
I will see what next November's renewal notice brings and what my plan of action will be.
