hehe....my 294 cam isn't far off 300... lol. :-)Jeremy wrote:Ben,
You and Justin need to form a "300 club".
Looking for info on the Schnitzer S5 - New crappy pictures!
Went down there to pay for the rest of the car and pick up the title to register this bad boy. Decided to bring my camera and snag some terrible shots (I was tired from programming and proving a stupid part on our new 4-axis CNC Mill). I promise better pictures when I pick it up either tomorrow or Thursday.
Anyway....I found it interesting how they federalized the car with where the sidemarkers were placed. The doors were left un-manipulated as well, so no impact bars in the doors (apparently they just replaced them with US Doors, then put the original Euro ones right back on).
Here are some pictures, and the color is Arktisblau Metallic if you couldn't already tell.
Still gotta pull those stupid ///M badges off...
Oh yeah? How about you.... oh fuck, do I really even WANT to start this war now?Ben wrote:
My dad wants to retrofit S38 Throttle Bodies at "Some Point". Obviously it won't be anytime soon.
Wiseguy wrote:Wow, another Euro Arktisblau car on the board.. except this time it might actually BE a fast NA one!
Wow, new concept!
We need to add a poll to this topic...
What poll options might those be? And WTH is wrong with S38 ITB's on an M30? Obviously the fabrication, but I'm sure the guy who fabbed up the plumbing for the Turbo M42 could handle this.
Wiseguy wrote:Oh yeah? How about you.... oh fuck, do I really even WANT to start this war now?Ben wrote:
Wow, new concept!
Thanks Tim!Tim in N FL wrote:Ben,
Thanks for posting the photos of this beauty. Congrats!
I'm looking forward to following your progress in bringing it back to par. It is the ONLY one I've ever seen stateside. 8)
Best,
Tim
I sure feel lucky, since the now PO said quite a few people were pissed that they missed out on the car.
The car really looks much worse in person, but a good cleaning inside and out would improve it alot. But not the awful clearcoat peel.
Anyway, if I make it down to V@V in 2008, I would be happy to let you take her for a test drive. This car especially with low miles drives amazing.
Best,
Ben
Just my $0.02:
This is a car worth saving, if it's a true documented Schnitzer, which I can only assume it is.
1. You'll want to do a full blown restoration of the body. You'll want to remove *all* the trim, bumpers, windows, door and window seals, trunk, interior, etc. Recover the seats, go through the interior and make sure it's up to snuff. When it's in for paint, have the front jacking points reweled/reinforced; and you might as well add in the sway bar reinforcements as well while you're in there. It's a big, expensive job, but necessary given the rust you've taken pictures of.
2. Once you complete that, you'll probably want to go through it mechanically from the suspension to the drivetrain. Replace any worn parts and put it all right.
I know that sounds like a lot (it is, I can see a restoration of the above easily going north of $10k). But the car will be spectacular when it's done, and it'll be 'done right'.
3. I'm also curious about that AC line that works it's way above the air filter cannister. It's not the same as the M5 or the 535i US one. Also, you have an M5 coolant expansion tank. Your upper rad hose is also not the E28 one.
-Chris
-Chris
Neat car. It's interesting to compare euro cars to see how they were modified to make it through the Federalization process when they were brought into the US - it seems like no two cars were done exactly the same.
Did this car have factory a/c or is it aftermarket? That may explain the odd routing of the coolant line Chris mentioned.
Looking at, I'm pretty sure that's the 533i factory system. I think they lifted the line so the front would clear that huge coil. I just noticed that the car has factory ABS, very cool for an 83.cgraff wrote:3. I'm also curious about that AC line that works it's way above the air filter cannister. It's not the same as the M5 or the 535i US one. Also, you have an M5 coolant expansion tank. Your upper rad hose is also not the E28 one.
-Chris
What intrigues me is the box in front of the condensor and aux fan. Any idea what that is, Ben?
Oh, and Chris, in 83 that would've been a 528e expansion tank.
uuuhh...no. take a look:Jeremy wrote:Looking at, I'm pretty sure that's the 533i factory system. I think they lifted the line so the front would clear that huge coil. I just noticed that the car has factory ABS, very cool for an 83.cgraff wrote:3. I'm also curious about that AC line that works it's way above the air filter cannister. It's not the same as the M5 or the 535i US one. Also, you have an M5 coolant expansion tank. Your upper rad hose is also not the E28 one.
-Chris
http://www.mye28.com/tech/rods_pages/id8.html
The 528e tank sits on the opposite side of the engine bay and has the overflow from the rad on the other side of the tank (near the cap) vs the M5 one (which has it on the far side from the cap).
-Chris
Another German tuner from the 80's.
Schnitzer competed with ALPINA & HARTGE back in the day.
Hartge had the H5S, H5SP.....ALPINA had the B9, B10 and the monster B7/B7S(E12). The ALPINA & Hartge catalogs offered diffenrt performance packages and ungrades. They all used the base 528i - being lighter and cheaper to modify.
They show a picture of their E28 and E30 in the E28 -5series book- the one with the black cover.....
I had a Hartge color catalog that Justin now has - Hartge offered everything under the sun. BMP was an authorized USA dealer.
ALPINA had - Miller & Norburn on the Easy coast.
West coast was Mike Ditel ( famous for the E21 345i recently restored to the tune of 60K) and KSK - Susan (Ripoff NOW!).
