How to post photos using Google Drive
In case anyone is interested in posting their pictures hosted on their Google Drive. Here is 4 easy steps.
Steps:
1. Provided you have a google account, open up your google drive and upload your photo.
2. Select the specific photo you want to share and select "Manage Access"
3. On the right hand side, under "General Access", select change the setting from "Restricted" to "Anyone with the link". Select "Copy link" and paste it into your post between the "(img) (img)" using the "Insert Image" button
4. Replace "file/d/" with "uc?id=". Then remove the following part at the end "/view?usp=sharing"
Example:
Here is the result:
Thanks
-M
Steps:
Example:
Here is the result:
Thanks
-M
Re: How to post photos using Google Drive
Looks.like a lot of work, but
Xactly.
Peter made it so easy back in the day.
Cool
After 30 min I still can’t get it to work.
Thanks for posting this! I had figured out a garbage way to do it a couple years ago but this appears to be a lot easier
Or just use this link and paste your drive pic link, copy it and put it between the hash tags
https://www.labnol.org/embed/google/drive
Oops!!!PilotHobs wrote: ↑Sep 19, 2022 10:10 AM Or just use this link and paste your drive pic link, copy it and put it between the hash tags
I’m using postimage. It doesn’t get any easier.
