Is it still possible to get an OEM replacement key that's been cut to match the existing key code? I have a blank key that I could take to a locksmith, but it would be nicer to just be able to buy one that's ready to go.
My existing key still works, just thinking about the future in case it decides to break some day.
Replacement key question
Re: Replacement key question
Depends on the vehicle. Ask a dealer if they can get you a cut key. They can supply until they run out for your lock.
A dealer will order the key from BMW cut to code. There is no limit to how many keys you can get for a pre-EWS (chipped) car. Cut keys from BMW have been known to have some additional "bumps" on the key like the machine they use doesn't care about some of the space between "teeth". I'll check to see if the system still cranks out key codes for our cars by VIN.
I wish the key code for my car was correct. Ordered keys decades ago and they were nowhere near correct using the key code for the car. Doubt all the locks were changed prior to me buying the car from BMWNA.
i've bought several keys from the dealer in the last couple years and all of them have worked great. hopefully your locks and lock accessories are all original to the car.
I don't suppose there are key decoder docs out there? Some mfg have documents that you can use along with a set of calipers to figure out what the code is based on cut depth at each position.
Dealer parts guy said they could look at the lock and the tabs in the lock and make a key based on the tab info.
Seems like there are lots of ways around getting a key unless it is one of the chipped keys we don't have.
The key I got back from the dealer also did not work. They then took a digital photo and sent that off. The next key worked. That was about 5 years ago.
Chris
Chris
