+1T_C_D wrote:Great idea but how about finishing some brake brackets first.
I'm in for hood release ash shwell.
I suspect you're right. I was noticing today that the pull distance of my handle seems longer than it used to be. The release point is now right up against the limit of the handle's range. In fact sometimes -- like when it's cold -- the release point is slightly beyond the handle's range and I really have to pull it hard too eek out that last bit of tension to get it to pop loose. I know this has to be straining the handle beyond what it was designed for.
I had this happen on my E36 after I swapped hoods.HayekFan wrote: ↑Dec 21, 2022 11:16 PM NOTE: about halfway down the thread there's a very astute warning that your hood may jam shut if you attempt to adjust it and don't get it quite right. The suggestion is to preemptively remove a couple of grill sections so you can access the underside of the latches and pop them loose if that happens.
