For Sale: Project Car: 1984 BMW E23 745i
Price: $1000
About the car:
-Starts, runs and overheats if driven
-Clean title
-Garaged
-Interior Buffalo leather good, Dashboard cracked
-DOT compliance conversion
-Transmission replaced
-A/C R134a conversion
-The head gasket is blown (Replacement part included)
-Replaced water pump
-Replaced freeze plug directly beside the cylinder walls, the piston rings are also likely to be cracked in at least two cylinders
-Turbo bearings are extremely worn
-Turbo seals leaking internally and externally
-Tie rods and control arm bushings are extremely worn
-Two bolts connecting strut housing to control arm are broken
-Intercooler is cracked—boost leak
-Intake hoses from turbo to intercooler are broken—boost leak
-All four shocks are blown
-Thermostat housing is cracked and leaking
-Front wheel bearings are worn
-Fan clutch is worn— not cooling properly
-Oil leaks
-Undercarriage rust
-Power steering cuts in and out when turning or applying breaks
-Sometimes does not shift into next gear, shifts fine in 123 mode
-HVAC is on default mode (defrost) and AC does not engage
-Cruise control does not engage
-Odometer does not work (plastic sprocket broken, estimated mileage 140,000)
-Onboard computer does not come on (fuse)
-One ABS sensor is faulty
-Muffler exhaust has holes from rust
-Driver side headlight is out (bulb)
https://imgur.com/a/y2aCFkr
SOLD 1984 E23 745i Project Car For Sale
Re: 1984 E23 745i Project Car For Sale
Message sent
