SOLD - 1988 535is
SOLD - 1988 535is
My 1988 535is sold On BAT
https://bringatrailer.com/listing/1988-bmw-535is-18/
Sold for $8150 on BAT It think the Seller fee was $99 and Buyer fees were around $450.
LACHSSILBER METALLIC (203)
Diff - 3.25 LSD
Sport seats - cardinal red interior
Car drives as it should, Handles great. (would drive it anywhere)
Current Mileage shows - 77,8xx last I checked on car fax/ vin check that was pretty close to the last recorded reading.
I really cannot tell you actual mileage but the Odometer does work.
I Purchased Summer of 2018 out of Dahlonega GA hoping to own the car a long time, convert to auto and make it nearly perfect.....
I finished the Manual swap and the maintenance but didn't get to the paint...
other projects came up. And I have to sell one.
So the E28 has to go...
Only rust I found on the car is on the fresh air vents in hood.
No rust in the doors, rockers, shock/strut mounts, pinch welds, wheel wells or under the car.
All bolts came off easy.. nice working on a rust free southern car.
Everything working:
Odometer
Windows
AC
Check panel
OBC
Lights, interior/exterior
Speedo, Tach
Heater Fan
AC fan
radio/power antenna
Trunk Tools are all there
Maintenance - (completed by me over the last 12 months unless noted by previous owner)
Brakes:
- Font and rear rotors and pads
- Brake lines Rear new soft lines(fronts have stainless, previous)
- New pad sensors
- Brake bomb
- Brake master (stock size)
- Brake booster (by previous owner)
Suspension:
- New bilstein HD front and rear shocks/struts on std springs
- New Strut bearings
- Front lower and upper arms with tie rods replaced by previous owner, look to be meyle HD and Lym
- rear sway bar links
- new dog bones
- diff mount
- Rear half shafts (axles)
Engine:
- Oil pan gasket (while I had the transmission out it was leaking)
- Water Pump (Hepu)
- Thermostat (Mahle/Behr 80deg)
- Starter (b35)
- Coolant Temp sensor
- coolant hoses (upper/lower/under intake)
- Coolant hose T fitting
- Radiator OE (New manual type No feed for auto trans)
- Coolant res
- BMW blue coolant (no green here)
- Engine mounts
- Exhaust (header back with new Cat (magnaflow) and OE muffler)
- New O2 sensor.
- fan clutch behr
- belts all of them (conti)
- alternator replaced
- Oil bar bolts replaced with new crush washer and lock-tite
- valves adjusted
- valve cover gasket
- cap and rotor
- plugs
Transmission:
- pulled out auto Transmission and replaced with 87/88 g260/6 replaced seals
- replacement driveshaft,
- new trans mounts
- new shifter bushings
- center bearing, guibo, and cross member,
- new clutch disk (OE Sachs)- Machined OE flywheel
- New throw out bearing
- New Clutch master, hose, and slave
- 3 pedal assembly (was cracked, reinforced and welded)
- New rear main seal
Other/interior/electrical:
- Front Sport seat leathers recovered (cardinal)
- Rear Seats Cardnial Replaced with good used.
- Replacement Dash 95% crack free
- M-tech I Steering wheel installed.
- Rear deck redyed
- Battery
- Fuses new ceramic ones
- Driver side B-pillar cover
- replaced 3 spoke steering wheel M-tech1
- Radio replaced with Blaupunkt bluetooth radio
- Speakers (factory amp removed) rewired front/backRear speakers replaced
- Gas tank vent lines replaced
- Fuel filter and soft lines replaced
- Heater fan replaced
- driver side tail light
- Front and rear bumpers (large ones aluminum replace)
- Hella H4 low beams sealed high beams
Wheels/tires:
Running Style 19 17" wheels Shown with new Kumho tires.
Also have e34 15" style 5 wheels with BFG 2015 tires in good shape.
Will send both with car.
The not as good:
- The paint, It is faded and needs a respray.
- It was a southern car and the sun has took it's toll on the exterior.
( Paint and body was next on my list) but she's straight and rust free...
- It still has the Auto TPS (throttle position Sensor). I have a manual TPS on a throttle body if you want it it will go with the car.
- Passenger power mirror does not work ( Will included two functioning black mirrors in good shape at sale)
- (REPLACED) Front sway bar links need replacement (boots torn)
Diff - 3.25 LSD
Everything working:
Odometer
Windows
AC
Check panel
OBC
Speedo, Tach
Heater Fan
AC fan
radio/power antenna
Brakes:
- New pad sensors
- Brake bomb
Suspension:
- new dog bones
- diff mount
Engine:
- Water Pump (Hepu)
- Starter (b35)
- Coolant res
- Engine mounts
- New O2 sensor.
- fan clutch behr
- valves adjusted
- cap and rotor
- plugs
Transmission:
- new trans mounts
- Rear deck redyed
- Battery
Wheels/tires:
The not as good:
Re: FS - 1988 535is Midwest
That's a great looking car for the money!
Pending
Did the price change on this? Thought it was 6950 range this morning but now has 8700 and new threads in online groups as well.
Nice example...
also noticed this...Rich in Tupelo wrote:Did the price change on this? Thought it was 6950 range this morning but now has 8700 and new threads in online groups as well.
Re: FS - 1988 535is Midwest - sale pending...
Typo... But still a bargain for the car.
PENDING SALE
Deleting the ad text undermines the helpful history for others who search the board and research values to make their own E28 purchases.brickwhite wrote:PENDING SALE
isnt it about time we make a rule about this? Just put SOLD in the title. leave the listing price, doesnt even have to be the final sale price but come on peopleAdam W in MN wrote:Deleting the ad text undermines the helpful history for others who search the board and research values to make their own E28 purchases.brickwhite wrote:PENDING SALE
I agree there should be a rule about this. I don't have any good suggestions about preserving images - those a much harder.
In either case, I pulled the edited-once ad from the Google cache, taken Oct 17, 2019 17:38:56 GMT.
Ad from then is below the break.
Edit: I would like to make it clear to everybody that I am in no way claiming this car is available for sale on this forum. I am only preserving the advertisement as it was for future reference.
My 1988 535is FOR SALE
Price [url=http://(%20$%206%209%205%200%20)](removed by request)[/url] obo
VIN - [url=http://%20W%20B%20A%20D%20C%208%204%200%205%20J%203%202%206%202%204%206%205](removed by request)[/url]
Clean Title in my Name.
Diff - 3.25 LSD
I finished the Auto swap and the maintenance but didn't finish the paint...
Everything working:
Odometer
Windows
AC
Check panel
OBC
Speedo, Tach
Heater Fan
AC fan
radio/power antenna
Power seats function (headrest too)
Spare and jack
Brakes:
- New pad sensors
- Brake bomb
Suspension:
- new dog bones
- diff mount
Engine:
- Water Pump (Hepu)
- Starter (b35)
- Coolant res
- Engine mounts
- New O2 sensor.
- fan clutch behr
- valves adjusted
- cap and rotor
- plugs
Transmission:
- new trans mounts
- Rear deck redyed
- Battery
Wheels/tires:
Running Style 19 17" wheels Shown with older tires.
Also have e39 Style 33 16" wheels with BFG G-force sports 225/50.
100 miles south of St. louis, MO 180 miles north of Memphis TN.
The not as good:
- Front sway bar links need replacement (boots torn)
Pictures: working on More.....(need more of interior.. will get them this week)
Diff - 3.25 LSD
Everything working:
Odometer
Windows
AC
Check panel
OBC
Speedo, Tach
Heater Fan
AC fan
radio/power antenna
Spare and jack
Brakes:
- New pad sensors
- Brake bomb
Suspension:
- new dog bones
- diff mount
Engine:
- Water Pump (Hepu)
- Starter (b35)
- Coolant res
- Engine mounts
- New O2 sensor.
- fan clutch behr
- valves adjusted
- cap and rotor
- plugs
Transmission:
- new trans mounts
- Rear deck redyed
- Battery
Wheels/tires:
The not as good:
- Beamter
Re: PENDING - 1988 e28
Very solid looking car!
Re: SOLD - 1988 e28
Sold for 8150 on BAT
Re: SOLD - 1988 535is
Price seems really low for a 5spd iS and a good color combo
Totally agree, and from looking at the comments section of the auction, so did a bunch of people. Paint it and install euro bumpers, and this car sells for $15K+ all day long on BaT.Adam W in MN wrote:Price seems really low for a 5spd iS and a good color combo
$15k minus selling price doesn't leave enough money to paint and euro convert properly.
Think the seller got what he was asking for the car originally or close to it, win win for both buyer and seller.
Me Likey! I think the sell is totally reasonable given the appearance and condition of this fine vehicle.
Maxine is a fantastic 15-footer with great potential and bones.
This car is all signed, sealed, delivered as Stevie would say
