No idea on the boost, stock blow-off valve is ~13psi. Vac pump you'd just have to remove the cam cover and pull the pump. 2 bolts or nuts, forget which. Its pretty easy and obvious once you have the cover off.
Nice work! Was the boost gauge already there?
One important thing if you've not heard this - never rev the engine while in park or neutral with the 4HP22 transmission. Yeah, I didn't believe it either, but it's real.
It will blow its seal.
I think there is some updated seal that fixes that problem if you rebuild it. Don't know the particulars but I know I've seen it before. I just don't rev mine because I don't feel like finding out.
Yes, I’ve heard that. No the boost gauge I’ve installed after turning up the pump and adjusting the waste gate. Currently set at 18lbs on stock head gasket. Been debating on putting on my HX35 but I probably should invest in a MLS head gasket first.
I'd honestly put an intercooler on before adding more turbo. Past a certain point you're just making more heat rather than really adding more air to the engine. Also needs more fuel to go with that extra air.
Yes and intercooler would go along with the hx35. I have a spare exhaust manifold and still trying to figure out how to space the turbo out far enough without compromising supporting the weight of the turbo. Also I’m not a fan of cutting into rad support, looking into water to air cooler.
I’m interested in this updated seal on the trans, wasn’t able to find any info on it. Anyone know about this?
personally i'm opting for the lazy man's "just don't rev the engine in park" solution. Mine shows no tendency to creep in neutral and it works perfectly fine so I think its OK for now.
Alright, well I did a thing. Going to put off swapping turbos for a bit. Found a 84 e28 at the local pick n pull a 533i with a getrag 260. Pulled the trans, pedal box, drive shaft, clutch slave and master. Shifter and linkage were already missing. $250.
Anyone have any suggestions on a clutch and flywheel that have done this swap?
that getrag 260 is not the getrag 260 you need. you need a 260 from a M20 vehicle since the m21 is based on the m20 block. your 260 is off an 533? so its a M30 260. it will be clocked all wrong and wont work. if you put the m30 and m20 getrag next to eachother you will understand. I would sale or trade that m30 5 speed box for a m20 5 speed box out a 325e or a 528e. Sorry! -Paul
Sonoma AutoX. [/url
[url=https://ibb.co/PGbFq9p]
Drifting. Yes, the auto...
Now this weekend, found a wreaked and abused E28 5 speed. Doing the swap finally.
nice!!! you will not regret it! makes it super easy to have all the parts you need. be sure to put the 6 timing pins in the new flywheel. for tach and fuel control. -Paul
kingoftarmace2004 wrote: ↑Oct 24, 2020 2:15 PM
gadget73 wrote: ↑May 26, 2020 9:34 AM
Do you have any recommendations on intercoolers?
I don't have the stock air box installed and have some room in the side. Was thinking it might be a nice place for a ALH intercooler?
