Manual shift swap - MyE28.com
MyE28.com Forum Index mye28.com is the BMW E28 5-Series Enthusiast Community
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   Calendar of EventsCalendar of Events   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Manual shift swap
Reply to topic    MyE28.com Forum Index -> Turbo diesel
View previous topic :: View next topic
Author Message
insane524td
PostPosted: Feb 07, 2012 12:44 AM    Post subject: Manual shift swap Reply with quote
I have an 85 524td auto. my friend has a manual ZF tranny out of a 97 328i, pedals slave and everything. Would that bolt up to my engine??? what would i need??
Back to top
View user's profile Send private message Send e-mail
524tdAviator
PostPosted: Feb 07, 2012 2:25 AM    Post subject: Re: Manual shift swap Reply with quote
It will not fit. You need a Getrag 260/5 out of a 528e, 325e, 325i, etc.
Welcome to the forums! I am anxious to do a 5-speed manual swap as well.
Check out this link for a nice tutorial on an auto-manual swap: http://www.mye28.com/tech/DaveKanTransGuide/
Back to top
insane524td
PostPosted: Feb 07, 2012 2:31 AM    Post subject: Reply with quote
Ok thanks I will have to stick with the auto till it blows. it seems to be holding up good. i will keep my eye out for the getrag. Ive owned this car for about 2 weeks now and blocked egr off wastegate and maxed the pump out. there a fun car. Its the second 524td ive had.
Back to top
524tdAviator
PostPosted: Feb 07, 2012 2:49 AM    Post subject: Reply with quote
Where in the USA are you located? They're great cars. I love it when I pull up to a store or gas station and people are confused as to why they hear a loud diesel in a BMW. smile
Back to top
Frybrid 524td
PostPosted: Feb 07, 2012 11:00 AM    Post subject: Reply with quote
A Getrag 265 will work as well but you'll need the elusive M20 bell housing for it.
Back to top
insane524td
PostPosted: Feb 07, 2012 1:42 PM    Post subject: Reply with quote
Yea everything i own has been diesel. Im located in Montgomery NY.
I would also like to put a better turbo on the car, they have a t3 flange but it doesnt seem like theres any room for a bigger sized turbo
Back to top
Frybrid 524td
PostPosted: Feb 07, 2012 1:57 PM    Post subject: Reply with quote
You can fit larger turbos on the M21 but the HP gain bottle neck is the Bosch VP-20 injection pump. More air from a larger turbo isn't going to help you if you can't pump more fuel to match. A ball bearing turbo would at least let you minimize the turbo lag.
Back to top
insane524td
PostPosted: Feb 07, 2012 7:17 PM    Post subject: Reply with quote
Its the ve pump arent the vp electronic? i maxed out the pump and create lots of smoke so i would assume a bigger turbo will do good because it seems to fuel decent.
Back to top
Frybrid 524td
PostPosted: Feb 07, 2012 8:31 PM    Post subject: Reply with quote
The VE and VP-20 are iterations of the same pump. See the stickies.
Back to top
altus22
PostPosted: Feb 29, 2012 1:13 PM    Post subject: Reply with quote
You can put a higher A/R turbine housing and wheel on the same center section as well as being able to put a larger compressor wheel and housing on. The former will flow more gas, but will spool up more slowly, whereas the latter will flow more gas in addition to increasing efficiency at higher boost levels.
Back to top
View user's profile Send private message AOL Instant Messenger Yahoo Messenger
insane524td
PostPosted: Mar 14, 2012 12:11 AM    Post subject: Reply with quote
How is the auto tranny in them? can they hold up to a decent amount of power? Mine seems to be good sofar.
Back to top
Frybrid 524td
PostPosted: Mar 14, 2012 8:41 AM    Post subject: Reply with quote
If you take care of it will regular fluid changes, the 4HP22 will have no problem.
Back to top
CoyoteStarfish
PostPosted: Mar 14, 2012 11:56 PM    Post subject: Reply with quote
Just.. don't ever free-rev the engine in neutral or park with the 4HP22. Burns it out. Myself, I found the standard swap to be very rewarding but it had a steep learning curve. There are a lot of small things not covered out there, despite the extensive documentation out there on the internet and this forum.
A variable geometry turbo will make this engine a lot more enjoyable but it is far from a bolt-on procedure. Remember that this car has no intercooler - which will even help with the factory turbochargers top-end power. Not so much acceleration, however. That is where the VGT would come in.
First thing is first, before you do ANYTHING regarding fuel quantity adjustments.. put a pyrometer and boost gauge on it. A exhaust manifold pressure gauge is helpful but not always necessary. The stock T3 turbo is good for about 150HP or so but the EGTs and exhaust pressures are way too high for this engine, so be careful. Excessive EGTs and EGPs are the main killers of these engines as they put a lot of stress on the already weak cylinder heads. That, and timing belts.
Back to top
View user's profile Send private message Send e-mail AOL Instant Messenger
insane524td
PostPosted: Mar 19, 2012 11:16 PM    Post subject: Reply with quote
That all sounds good. im looking for a good MLS head gasket now so i can run some more boost, and also a good radiator.
Back to top
insane524td
PostPosted: May 14, 2012 11:52 PM    Post subject: Reply with quote
I found an old E28 bodied bmw with a 5 speed, dont remember the model or year. I will have to check, but would this Manual be the 1 that i need for my 524td swap??
Back to top
PostPosted: May 15, 2012 12:49 AM    Post subject: Reply with quote
If you don't know the model or year, how can anyone tell you whether or not it will fit?
Back to top
Frybrid 524td
PostPosted: May 15, 2012 8:45 AM    Post subject: Reply with quote
You may as well give it a shot. What's the worst that can happen?
Back to top
CoyoteStarfish
PostPosted: May 15, 2012 10:38 AM    Post subject: Reply with quote
The 524td uses the M21 engine which shares block geometry and many bolt points with the M20 (gasoline) - so the M20/21 engines are basically plug and play. The only two E28s with the smaller M20/21 blocks offered in America were the 528e and 524td. Those are the ONLY ones that would work for you.
If it is any of the following: 533i, 535i, 535is, or M5 - then it will be M30 powered which is the larger block and has a different transmission.
Back to top
insane524td
PostPosted: May 15, 2012 6:19 PM    Post subject: Reply with quote
Ok perfect Thanks!
Back to top
insane524td
PostPosted: Jun 14, 2012 5:47 PM    Post subject: Reply with quote
Any1 interested i have my 86 524td for sale 2000$ runs great new timing belt. 223,000mile. also will have a 524td im parting out if you need something let me know
Back to top
524tdAviator
PostPosted: Jun 14, 2012 7:32 PM    Post subject: Reply with quote
Might want to put this in "For Sale" section?
Back to top
Display posts from previous:
Reply to topic    MyE28.com Forum Index -> Turbo diesel All times are GMT - 4 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Index |  Support MyE28.com |  Site Policies
Copyright © 2005-2013 MyE28.com
Powered by phpBB © 2001, 2005 phpBB Group
